Well, I got the head studs in. I ended up having to chase the threads in 2 holes (oddly enough right next to each other) and the studs threaded into place without issue. The issue I ran into was that the Tap that ARP sells you is 3.5” long and the threads start 3.4 inches into the block. Thankfully, by the grace of god the 5/16th deep socket was the perfect size to fit the end of the tap as well as the hole.
My contraption
I damn near shiznit my pants trying to decide should I continue at this point and potentially **** myself or stop. I live dangerously and kept going, thankfully one more turn and it reached the bottom.
Then I can pull it out with my magnetic extension.
Now, all the studs are in their place and ready for the heads. I’m not too certain how important this is but after screwing the studs by hand, as per ARP instructions, into the holes and touching the bottom I measured them and they were all within 2 or 3 thousands of an inch (3.556” was a common number) minus 1 which was 3.49X".
Studs are in!! I also got my head gaskets and heads in from JPC yesterday so as soon as I can find the old head gaskets I will be putting the heads on to prevent anything from falling into the combustion chamber or cooling passages.
My contraption
Thread Chaser Extension
- ARP M12x1.75 Thread cleaning tool – Part # 912-0008
- 5/16 deep socket
- 3/8’s extension
- 3/8’s socket wrench
