Output Shaft Flange Nut Location for TSB 19- 2135?
After my latest track day I noticed my car experiencing surging issues and cruise control not working as similar to what's described in TSB 19- 2135. (https://static.nhtsa.gov/odi/tsbs/2019/MC-10162060-0001.pdf)
Can someone tell me if this is the output shaft flange nut that would need to be replaced or tightened? I'd take it to the dealer but they are slammed for the next 2-3 weeks and if it's something simple I can fix myself I'd rather give it a try.
I also had the same issue. I had a post about two years ago about the TSB and getting it taken care of. Question, can you please explain where under the car the picture is taken?? If it happens to me again, I would like to be able to locate the nut. Thanks
Right underneath the shifter. Nut is on the back of the transmission where the driveshaft connects.
Latest lap times
