Pirelli Slicks in 19s
For those of you running these tires on the GT350 in general, and the GT350R in particular, how many heat cycles do you average before they need replacing? What wheels are are you using?
8,522
8,583
This question always gets varied answers, but best to talk to folks who run the track you plan to run the most often. I sometimes would only get one weekend at one track I run , yet on another it was not unusual to get 3 weekends.
8,375
Great info for all, but one thing that we should make sure folks add when discussing hot/cold temps , is to designate whether they are discussing on a GT, Boss 302 , or GT350. Solid rear axle or Independent, range of camber in the front between a Boss and a GT 350, tire size ( 18 or 19 ) can all affect the temp range and they will likely be different between these cars simply due to suspension dynamics, imho.
Nuff said, now commence contributing , ha.......
True...kind of. You still must meet the performance parameters of the tire no matter what car you have, independent or stick axle..in the end, it really doesn't matter how you get to the parameters of the tire, but if you exceed those parameters, the car won't handle. The tire parameters that we use on the Mustangs, are identical to the ones we use on the GT3 Porsche..until they changed compounds which changes parameters so you get to chase it again.
As a Phoenix customer, I was invited to a track day a couple of weeks ago at NJMP with Joe Aquilante (in his Z06) and one of his young guns in his T-3 Mustang as he prepped for the run-offs. It was my first real test of my car since Phoenix did the clutch, rollbar, set the ride height and general settings. They also modified the shock tower so I can get up to -5.0 camber but set it at -3.5. I was running Pirelli 305-680-18 DH take-offs set at 26 psi cold per Joe's recommendation. I went out and got lapped by everyone on track......all race cars and a GT350 but still! I could not get the front end to turn. There is a section of right-left-right transition that just killed me.....couldn't point the car and had to lift until I could get the front to track. I tried to check tire temps after the first session but my battery died. Pressures were around 31. But I noticed the first front temps I got before it died showed and inner reading that was 70-80 degrees higher than the outer edge and it didn't look like I even used the outer 3-4 inches of the tire. Too much camber? Too much pressure? I'm running there again this weekend and will drop camber down to -3.0 (although Joe recommended at least -3.5 if not more) to see if wear and temps are more even. The front Koni's (Cortex single adj) were set about 1/4 from full soft. 32mm front Strano bar on middle hole. Should I increase compression? I have not played with the JRi's in the rear so I do not know what they were set at but I have an 18mm rear bar. Rear traction was good as expected but it's killing my front grip. Any suggestions?
I ended up running 2.5 degrees negative camber in my Boss when I ran the 305-660's. I tried 2.7 which was just a little too much. This was using tire temps and handling to find the best setting. I also ran a 18mm sway bar. For tire pressures I started with 26psi cold. Once they got hot they would run 34psi front, 33psi rear.
8,522
8,583
Somewhat typical for tires after the end of the Season for various sports car Series. May need to run something else in the meantime and if you are looking for pretty decent life and flexibility , the Michelin Pilot Sport Cup 2s are a good alternative . Sure they are more expensive , but they are less than some other alternatives. If you want even more aggressive grip , go for a Hoosier R 7.
Otherwise , used Pirellis and likely Michelins will pop up next year as early as late February or March ( Michelin could be in greater supply as they will be the new tire of choice for what was the Continental Tire Series ).
j3st3r
Brian S.
604
376
Tennessee
I already run an alternative I feel is the best option which is the the RE71. I would love to run the Hoosier R7's, but I am just not willing to spend the almost $2K for sticker Hoosiers. We have contacts at most of the teams, and have checked with them throughout, problem seems to be the Ferrari challenge series is no longer running them, and all others are on 18's, with Michelin taking over a couple other series.
8,522
8,583
Should be more choices next year and if you are running road courses more than Autocrosses , would suggest the PSC2s over the Bridgestones as they will be faster ---- and have more life than an R7 , yet not get greasy as quickly as the Bridgestones.
j3st3r
Brian S.
604
376
Tennessee
Should be more choices next year and if you are running road courses more than Autocrosses , would suggest the PSC2s over the Bridgestones as they will be faster ---- and have more life than an R7 , yet not get greasy as fast as the Bridgestones.
Said it before...I would put the "hoosierstones" RE71's up against the Cup2's any day, definitely do not believe the cups would give more life than the stones.
8,522
8,583
Instruct at two tracks and with NASA , and a lot of guys around here run RE71s as they autocross and the Solo Nationals are run about 60 miles from me down in Lincoln , Nebraska. The Bridgestones are the " King of the Autocross, " with only the BFG Rival S very close in my estimation, but I can categorically state that the Cup 2s are faster on a road course, though, as you mentioned they may not last as long as the RE71s. I guess I am not sure what you are looking for , more speed or just longevity? I do know from a lot of students and friends that the only real downside with the RE71s is they get greasy , pretty fast , for accomplished drivers.
Just throwing out alternatives and the Pirellis have been great , because if you trash one, not much cost to get another, but maybe next year with the Michelin slicks ( which are even faster than Pirellis ) being on more cars , there will be another used racing tire alternative?
[email protected] You can always contact me here , as have access more often than the Forum.
Thanks for the note.
j3st3r
Brian S.
604
376
Tennessee
Yeah instructor here too. Really like the way the Pirellis felt on my 13, liked them much better than the Continentals. I like the RE71's a compromise from the Pirellis/Hoosiers as a reliable, fairly quick tire I can track and AutoX, and drive on street if needed. I want the Hoosiers/Pirellis for all out speed/lap times to really see what the car can do. I have noticed though the 350 is incredibly hard on outside edges even with proper inflation and as much camber as I can throw at it when really pushing the car hard. Our local track is 3.2 miles 23 turns, mostly high speed right turns, so the left sides tend to wear pretty heavy. I am hoping the DH compound can last me at least a few events between a couple of my local tracks (NCM, Barber, RA, VIR).
