Pre Bleed throw out bearing.. good or bad idea, I'm not sure
20
17
Minnesota
I had to replace my throw out bearing for the second time and remembered how hard it was to bleed it from the first time. This time I decided to "pre bleed" it.
I used a beaker with brake fluid in it, stuck the pipe fitting in it, pumped the TOB until all the air bubbles stopped. Installed it in the bell housing being careful not to squeeze it or tip the pipe end downward to keep the fluid in. Installed the plastic interconnect and used the plug that came with the new clutch like to plug the line while I installed the transmission.
Now the down side is, the TOB is full of fluid and needs to bleed out while installing. My plug popped off and fluid ran down the side of the tranny and onto the floor.
The upside is, I put vacuum on it for a while and pumped the clutch a few times and it was good to go.
There's always trade offs, Dang it.IMG_20230127_190530191.jpgIMG_20230127_191243590_HDR.jpg
1,178
1,184
Lenoir City TN
You are on the right track, but didn't quite get to the finish line. Attach the braided stainless clutch line to the fitting before sliding the transmission into place. Fish the clutch line up from the bottom as the trans gets close before you preload the throw out bearing and connect the top. Then slide the trans in with no mess.
PaddyPrix
728
1,088
San Diego
Agreed, only found this out after cursing in multiple languages trying to get those annoying clips in, as with longtubes, the body shell, and the transmission, there's not much room to wiggle that on. So much easier by comparison to fish that line back up from the top of the engine bay.
20
17
Minnesota
Nice!
1,178
1,184
Lenoir City TN
I figured that one out while installing the second transmission last year. The first one I did what you did and squirted fluid all over as the tob preloaded.
20
17
Minnesota
The wire clips are quick attach. Preinstall the clips, press the line in until it snaps. done!
I tried installing the hose then the clips in the beginning of the first time, then figured out they are quick-tach.
PaddyPrix
728
1,088
San Diego
:oops:
Times like these I wish I had read the instruction manual.
