Actual spring rates the car sees have to take into account the spring rate from the rubber bushings, any rubber mounts and the tires. Damping has to account for the "shocks", any rubber bushings, rubber mounts, and tires.
The sway bar end links are the same for all mustangs including all versions of the GT350 track pack, tech pack & R. The Rear R sway bar is different then the non R.VoodooBOSS said:Thanks Jason. So both F&R? What about the R shorter rsb end links? Thoughts on adding that to possibly balance the front and rear? I'm have cup 2's in 305 square for the track.
VoodooBOSS said:@JAJ thanks for calculating the effective rates. Now I'm really confused. Sound like you have a chart of this, if so can you please post a screen shot of it?
8250RPM said:The sway bar end links are the same for all mustangs including all versions of the GT350 track pack, tech pack & R. The Rear R sway bar is different then the non R.
bpracer said:Do you know how it is different? The diameter is the same from what I've read.
VoodooBOSS said:So making the bar shorter effectively makes it stiffer. Are the front bars the same?
Gt350 R. Fr3z 54772 Gbpracer said:Do you know how it is different? The diameter is the same from what I've read.
When I look up the part using both an R and my VIN on fordparts.com, I come up with the same part 5A772.
This is the after height, it looks the same to me. All the after heights were within an eighth of an inch, some even higher. Maybe the springs will take a set, one would hope not or they aren't good material.bpracer said:Having two sets of springs with the same ride height and two different rear sway bars allows for quite a few tuning combinations to try for different tire widths, etc.
8250RPM said:Gt350 R. Fr3z 54772 G
Gt350. Fr3z 54772 E
This pic is with GT350R springs installed? Do you know your before and after height measurements?bpracer said:
8250RPM said:This pic is with GT350R springs installed? Do you know your before and after height measurements?
Are the tires in the pic stock gt350 tires sizes? Can't make it out on my phone.
Did you do a suspension relearn?
bpracer said:Stock MPSS tires
I don't know about a suspension re-learn?
Before
LF 27 7/8" RF 28"
LR 28 1/8" RR 28 3/16"
After
LF 28" RF 28 1/16"
LR 28 1/8" RR 28 1/4"
A quick measurement and they are probably 1/16" -1/8" lower now, definitely not 1/2" lower over the original springs.
8250RPM said:Something doesn't seem right about your ride heights. The R sits 1" lower then the non R and the tires alone are 1/2" of that. So the springs should drop it 1/2". A relearn is needed anytime the suspension is serviced. It must have all 4 wheels off the ground and the cars weight supported on a lift or jack stands. A scan tool is needed to do the relearn.
