6,553
8,204
JDee
Ancient Racer
1,808
2,012
5 miles from Mosport
So that's a 540 CCA battery and it starts your car no problem? I've been trying to find out how lean one can go on that CCA value without much success. I really think this is fairly cheap weight loss from the right end of the car, I'd just stick the tiny battery in for track days and take it out for DD use, but if I cough the thing on track I want it to restart! Being boosted though, is your compression ratio lower than a Coyote would be?
6,553
8,204
I'm about 10.5-1 compression. So far it's been fine.
I always carry a jumper box just in case but I haven't had to use it yet.
More CCA is always preferred, but Kevin bought one of these and wanted me to make a mount for it so the easiest way for me to do that was to get the same battery and make a mount for my car, then duplicate it for him. I guess another track friend of his has run the same battery for a couple years, so it came with a good recommendation.
6,553
8,204
6,553
8,204
Totally, as with a lot of stuff found on the interwebs. But it's worth a lot more when the source is very credible and has been there and done that. ;)
Ooohhh....he thinks I'm 'Credible".... :p
6,553
8,204
6,553
8,204
What is the consensus on make and model for a lightweight battery for a track car. (not a DD)
I wouldn't say there's consensus, but I think one of the lightest lithium variants that you can find would work for track only use. I wouldn't use one that's 16V if you are keeping the stock PCM and OEM electronics. I'd get one that's spec'd for 14.4V to 14.8V charging range and a charger that will top-off in that range and preferably a storage mode that will keep state-of-charge between ~50-60% to ~75-80%. Most Li based batteries will last longest if stored in that range. Storing at a full charge speeds up degradation for Li batteries.
I have a charger that is capable of doing top-off of a Li batteries, but I went with a lead-acid for cost and reserve capacity / Ah for street and track use.
1,936
2,036
Michigan
+1 on Braille. I used the prior version of this on the Boss and have moved it to the Race Car. The newer version has the same capacity but is slightly smaller: https://www.braillebattery.com/index.php/braille/product_batteries/g30
Has anyone seen a bracket for a light weight battery which has room to mount a pump for trans cooler?
There is space even with the battery in the same orientation:
With the Battery box attached to the firewall, Distance from front of Battery box to strut tower is 8" on S550 and would be 5" on the S197, as the firewall is 3" closer to the strut.
I used the space for a solenoid and positive cable junction terminal, but a pump would fit -- you'll need to extend both battery cables.
6,553
8,204
Used the same FRP bracket in the Boss. It came with the B2015 kit from Tire Rack for less than I got the other battery from Jegs.
At least this time I put the charger pigtail on the lower terminals: :rolleyes:39617060874_2f4354a0ee.jpg
I didn't take pics, but only put permanent reflective insulation on the inboard side and back. I plan on zip tying some on the front for the occasional track day.
With the battery tray out, there's a TON of room to mount other equipment.39617064404_1394626e9f.jpg
This battery does need to be charged/driven regularly
13.18V - Disconnected after charge and 24+ hrs of 13.6V float.
12.99V ~14 hrs.
12.92V - 1 day
12.85V - 1.5 days
12.82V - 2.5 days
12.75V - 3.5 days <---add/edit
12.71V - 4.5 days <---add/edit
The solar charging on the FakeR has been working well. I blocked a couple of the cells on one panel to lower the voltage a bit for bright days. Today, it's overcast and both panels are in the windshield and it's floating at 13.30V. Bright days I normally see in the 13.6V to 13.8V range. One panel is enough to maintain charge, but the 'throttled' two panel arrangement works better (IMO) for leaving the same setup regardless of weather. Pushes more amperage over slightly lower voltage than one panel.
Panel with 3 cells blocked (currently at 2 blocked)
Tested one in the passenger window facing SW and it would extend the charge period, but not worth the hassle and completely unnecessary.
TymeSlayer
3,787
2,741
Brighton, Colorado
Grant,
I too thought of going this route when my OEM battery died but needed one fast so picked up another OEM replacement at the tyme. I am curious though as in your picture, I see this Braille up close to your Peterson breather can. If you had chosen to, could you have mounted the Braille further away from the can? (To the left in the picture)
Mine is located pretty much where your's is and the Battery is too close for comfort. My Peterson can is mounted by the cowl rivet from above and it does look like your's is mounted to the firewall but they are in the same general area. I'd actually like to migrate mine to the left a bit more but the OEM battery gets in the way.
Kirk
Tyme- It certainly could be moved outboard a lot. I mounted it inboard and back a bit mostly for CG reasons. I considered angling it a bit + forward and - back, but I thought it looked weird.
Overhead pictures might show better than words or the previous angled pics:
With the positive cover moved:
I'd be a little more concerned if I used the plastic rivet instead of the nylock nut and bolt to mount the breather.
TymeSlayer
3,787
2,741
Brighton, Colorado
Thanks Grant.
My can actually touches the red terminal boot and I can see some evidence of rubbing, thus the reason I asked. I'm just not comfortable with the way it's set up right now and there's no moving the battery any further to the sidewall. By the way, I use the push rivet to hold it in place but removed the pin and use an black oval head sheet metal screw to secure the rivet in place. It holds the bracket nice and tight.
Even though I have a new OEM battery, I mat still go this Braille route as well.
If it's still in there, you could remove the spacer/block on the outboard side and I think the battery should move up to another inch outboard. Otherwise, it might be easier to make the breather sit just a bit more inboard. Tweaking the T-bolt clamp, bracket and the AN hose might help pull it in enough.
I didn't have any rubbing with the breathers in either car when they had the OEM batteries in.
