Guys, I just installed a new set of DBA T3 4000 Rear rotors. Sense then I now have a vibration coming from the rear on my test drive. It starts at 65 mph and very noticeable. The vibration was not there before the rotor swap. The rear rotors were the only thing that changed.
lugs on wheels are tight
no weights missing on rims
there was no right / left markings on the rotors. could there be a L & R?
Rotors looked in perfect condition. cleaned with brake cleaner to remove oils
brakes are smooth
I know I can reinstall the OEM rotors to see if its the rotors but figured I ask the pros first.
where could I have gone wrong?? any and all help is welcome.
If anyone will know it will be the BMO members...HELP
Thank You
brakes are smooth
Thank You
