SN95 Rebuild Cobra R 4 piston brembos
10
8
Columbus, OH
I noticed tapered pad wear on the lower piston area on the driver's side of my 97 Cobra running 4 piston Brembo calipers with Carbotech XP12 pads and Girodisc 13" rotors. The dust seals are destroyed. I don't notice any leaks, but I wonder if replacing the seals will help at all. Does anyone have a part number on a rebuild kit? Any information as you why I am getting tapered pad wear? I didn't notice any on my last set of XP12 pads on solid one piece rotors. The brakes also have 3' ducting to them with Ford Racing wheels running 255/45/17 Falken RT615K+ tires.
Brembo 2000 Cobra R Caliper parts (M-2300-X or 1E5.6001A):
  •  Dust boot, 36mm (2 ea caliper) - part# 20.4872.44
  •  Dust boot, 40mm (2 ea caliper) - part# 20.4872.46
  •  Pressure seal, 36mm (2 ea caliper) - part# 05.7224.44
  •  Pressure seal, 40mm (2 ea caliper) - part# 05.7224.46
  •  Piston, 36mm (2 ea caliper) - part# 20.7050.55
  •  Piston, 40mm (2 ea caliper) - part# 20.7050.57
  •  Bleeder screw (2 ea caliper) - part# 05.2812.13
  •  Bleeder screw cap (2 ea caliper) - part# 05.1502.20
  •  Brake pad pin guides (2 ea caliper) - part# 20.5116.25
  •  Caliper retainer spring (1 ea caliper) - part# 20.4196.71
  •  Bridge tube (1 ea caliper) - part# 06.4518.49
    Bleeder screws: M10-1 X 30
    Banjo bolts: M10-1 X 29 (long)
    Goodridge SS lines: Kit #12362 (90.3503L & 90.3503R)
Can't say how easy/difficult they will be to source though.
10
8
Columbus, OH
I decided to leave the brakes after seeing similar tapered wear on other Brembo calipers in newer condition. The deteriorating boots shouldn’t affect anything, but I’ll keep a close eye for any leaks in the future. Thanks for the part numbers.
