Hi team,
I have a clunky rear sway bar that is caused by a worn bush in one of the drop links. The rear swaybar on the Laguna Seca is 26mm (CR3Z-5C488-J) and the OEM replacements from Ford appear NLA.
Does anyone have any suggestions on a solution? I can't seem to find any direct replacements from other brands. I assume I could remove them and get the current drop links re-bushed somehow, or can you get a 25mm one from a normal Boss (CR3Z-5C488-S) and modify (clearance) the bush to fit the 26mm bar?
Any help is much appreciated.
