S197 racecar parts: wheels, suspension, trans, driveshaft, brakes and more
captdistraction
GrumpyRacer
1,955
1,699
Phoenix, Az
Teardown sale has started: all parts located in Phoenix Arizona. Delivery free in Phoenix, shipping available upon request. I’d like to minimize effort in trying to split things up but will (though value savings may not be there). If requesting a split, its more likely I’ll go for it if you have another party wanting the other half.
Revised sales list:
Brake consumables package (Track people): (86lbs of stuff) - $375
1 set DBA 4000 series rotors, 32mm thick (30mm min), bedded with PFC08 compound
8 sets of s197 brembo pads: 1 set PFC 08 pads – 7-8mm depth, 4 set PFC 01 pads – sets have between 4-5mm, some pads have 6. Can mix and match, 1 set ST43 pads – 9mm depth, 1 set EBC Blue pads – 5.5mm depth
1 set 0.5 mm titanium shims
2 rebuild kits (seals, boots), 3 spare bleeder valves, crush washers
Locals: Free to good home – second set of OE blank rotors (just not worth shipping, 31.2mm)
S197Brembo brake package (71 lbs) - $700
2 cerakoted S197 Brembo brake calipers, loaded with OE Brembo/Ferodo pads (4.5mm), ALL hardware, mounting bolts, Russell speed bleeders installed at all locations. Recently rebuilt with new factory seals and boots.
Front stainless Russell DOT brake lines, attached to calipers (and filled already, bolt and go)
2 front rotors, 32mm (30mm min spec)
$700 (I will include installation for those local, I’ll install on your car and bleed/test the system, takes about 45 minutes) OR $900 with above track consumables kit
MT82 transmission – AC revision transmission (bellhousing has integrated spacer). Had a clutch failure, the bellhousing has a broken chunk. I can have this welded ($50), and will not impact function. Transmission recently filled (as in 10 min of runtime) with AMSoil Ben Calimer mix fluid. No issues, no whine. Just the physical damage to the bell that does not impact function. Includes rear mount (not pictured) - $450
Aluminum driveshaft (DSS). Includes rear adapter plate and hardware. No issues, ran great with the MT82, super light compared to stock. 3.5” diameter $550
Eibach adjustable 24mm rear sway bar – signs of use/rubbing here or there on the paint. Bushings replaced in 2016 - $150
J&M polyball LCAs – great for road course use, excellent shape - $90
images in no particular order:
5ab0994d65030d68aa9cdc5a04888f19.jpg99f185cef939c959f564445b4224b8d5.jpge6dffe2748cd4a6f08baa07717f493ee.jpgd0244d1f8044ea59705bfa144566230e.jpg9623c3b4aa73287a55d19de28215073a.jpg6a50d6479e91a32971702fe97c7a66d9.jpg
j3st3r
Brian S.
604
376
Tennessee
I know its early in your sale, but if you get to a point with the brake kit and want to sell all of the misc/accessories(seals, pads, braided lines, maybe rotors, etc) I would be interested. I already have Brembos and rotors, but would love to have service items
captdistraction
GrumpyRacer
1,955
1,699
Phoenix, Az
If I can get a buyer on the main setup with just one box of pads, etc. I can do that.
Those interested in wheels, this is what I'm finding in shipping costs via freight:
1 set of wheels/tires, made into a barrel with plywood base, 25x25x52 at 190lbs typically is around $175 to most destinations
2 sets of wheels/tires plus spare wheel on pallet, 40x48x48 at 420 lbs is around $288 to most destinations.
5,288
4,291
They may be spoken for, will follow up on the others as no one has gone for the brake package yet (and I found yet another box of pads making it 8 sets I think)
Sent from my iPhone using Tapatalk Pro
Ooohh.. so tempting!! Dam credit card is maxed out
Going Tremec?
