SOLD! 2013 Vortech Track pack M6 Sterling Gray 23k Miles
Price
$26000
SOLD!
2013 Mustang GT
Sterling gray metallic
Base Model with track package and tech package
23k Miles
2nd owner. All work within the last 5k miles
Vehicle was bought with 17500 miles currently 23k
Exterior:
Full detail with purchase
Paint Excellent Condition.
Covered when Stored outdoors
Wrap will be removed.
Carbon hood vents
Smooth deck lid Panel
California Special Spoiler (oem not knock off)
Tinted fog lamps
510 aero (Sam Davis) side splitters
Gt500 rear valance
Interior:
Boss 302 steering wheel
Brand new Cobra Motorsports seats (xl version for a little more room)
Planted seat mounts
Watson 4 point roll bar
Watson rear seat delete
Lower seat harness mounts
Aero scan gauge and roush vent mount
Kicker speakers front and rear
Driver visor with garage door opener
Tinted windows
Engine:
Vortech v3 6 rib kit
Competition Inlet
Beefcake racing torque booster with 3.33 pulley, tial waste gate and gates green belt. Limited to 10 PSI
ID1000 injectors
Ported Boss Manifold
JBA Cat delete and H pipe
13-14 GT500 quad Mufflers
Peterson externally vented catch can
Upgraded aluminum coolant tank
Triangle speed billet oil pump gears.
Mcleod RST clutch and lightened steel flywheel
Mcleod braided clutch line
MGW shifter and Delrin ball
Dynotech one-piece aluminum driveshaft
New battery
New engine harness (replaced 1k miles ago due to battery corrosion.
Suspension:
Lowered with Eibach Street Springs with new strut bearings
Maximum Motorsports caster/camber plates
BMR full rear suspension in hammertone color
Adjustable panhard bar and upgraded panhard bar support
Adjustable upper and lower control arms with poly/ rod end mounts
Lower Control arm mounts
Upper control arm mount
Also, a set of weld on boxed subframe connectors not yet installed on the car
BMR driveshaft loop
BMR radiator support (to help clear all the supercharger piping.)
BMR Front strut brace
Wheels/Brakes:
Forgestar F14 Gunmetal (match the car vey well)
20x9 front 20x11 rear
Nitto Invo Tires (tires has a decent amount of life)
255/35R20 front 315/35R20 rear
ARP wheel studs front and rear.
Stoptech Slotted rotors front and rear
Hawk 5.0 pads
The car makes 626 RWHP and 550 RWTQ. It was tuned by Shaun @ AED at his shop. If converted to E85 the car can easily make 700. The car rides awesome for lowered track-oriented car. It is loud and fast! But can be driven comfortably with no issues. The car will be sold with all stock parts. The stock seats will be installed for safety (proper airbag operation). Also, if sold in California is will be turned back to the stock supercharger install so it will pass smog. No test drives without cash in hand. The car is handful with a lot of power. Just don’t really find the time to drive it anymore with too many hobbies. Not in a rush to sell.
26K OBO.
(If price drops too much, I will remove the seats and keep them for another project.)
Located in Livermore, CA
Let me know if you have any other questions.
Thanks, MikeIMG_9808.JPGIMG_9809.JPGIMG_9810.JPGIMG_9811.JPGIMG_9812.JPGIMG_9813.JPGIMG_9816.JPGIMG_9817.JPGIMG_9818.JPGIMG_9819.JPGIMG_9823.JPGIMG_9824.JPGIMG_9825.JPGIMG_9830.JPG
