Square vs stagger
Looking at new wheels and wondering if I should go 285 square or 285 front and 305 rear? I use car for both autocross and HPDE plus 3000 street miles in the summer.
GT Track Pack with springs and koni's.
Thoughts?
5,287
4,289
I would really recomend going 305 square or bigger... Or at the very least 295. Our cars need all the rubber they can get! Not to mention that a square setup is great for rotation etc that can save you $$$$ as well.
Norm Peterson
Corner Barstool Sitter
939
712
a few miles east of Philly
Worth reviewing the last post in your 'Oversteer' thread, unless you're going to go really crazy with wheels wider than 11" (which would take 285/xx's off the table).
The car in my sig wears 285/35's on 18x11's, and (hopefully) at some point that's not going to be quite enough. Turns out that the section width of a 305 as mounted on 11" wides isn't as much wider than a 285 on 11's as the tire size numbers suggest, as the 285's are stretched outward by about 10 mm. This is mostly important for fitment, because strut-side tire & wheel clearance gets a bit skimpy.
OE mfrs are starting to put 305/30's on 11" wide wheels as production stock.
While I'm sure it's possible to tune your car around either a 'square' or 'staggered' wheel/tire setup, a front-heavy car without a power adder doesn't have nearly as much reason to stagger. The front end is the heavy end, and it's the end that gets the cornering started in the first place.
Norm
Norm Peterson
939
712
Should, though the fronts would definitely require spacers (WAG - 3/4" or 20mm) and you might have to trim the rear shock boots a bit. I also trimmed the rear tiedown brackets, this not being absolutely necessary but those 'bumps' can get in the way of easy tire removal.
Norm
Why not go with 18's?
Don't want to go shorter. I would need to shift 4th a lot more often tracks i run. Price point is great for this flow formed wheel.
