Hi All, I'm running MM Caster/Camber plates and their front track pack springs on Koni Yellows with an Eibach front anti-rollbar. Rather stiff setup. I was getting ready to install my bump steer kit and found the upper strut mount bearing blown up. Is this from a misalignment during initial install of the MM plates or are these things just weak junk and there are better options? I will say I have no clue if these are the original mounts or not as I'm not the original owner, but I'm willing to bet they are with all 110,000 miles on them. I suppose I should have used new ones when I installed all of the other suspension components. So maybe the age/mileage plays a part in this failure? Thoughts?
