Tire Preparation
492
387
DFW, TX
The tread depth is very shallow on these tires, so nothing to shave.
Can't answer about heat cycling, Tire Rack, I assume. I've never had it done.
Ordered MPSC2 tires online and had these two track prep options
  1. Heat cycling
  2. Tire shaving
Does anyone have experience with either of these?
8,522
8,583
Probably would not have shaved ( they have 4/32nds and they likely took them down to 2/32nds ) ,though heat cycling usually has some benefit with many tires --some actually stress it as imperative ( Hoosier for instance).
Here's what I found about shaving
Track and Competition DOT Tires
The following tires are manufactured with only 4/32" to 4.5/32" of molded tread depth and do not require tire shaving for autocross or track use.
  • BFGoodrich g-Force R1
  • BFGoodrich g-Force R1-S
  • Hankook Ventus Z214
  • Hoosier A7 Radial
  • Hoosier R7 Radial
  • Toyo Proxes RR
Most other Track & Competition DOT tires begin with 6/32" to 8/32" of molded tread depth and typically do not require shaving for autocross use, driver's schools, track days and competitive track use in dry conditions. Shaving these types of tires may offer a slight improvement in initial lap times, but will result in a commensurate reduction of tread life.
Michelin Pilot Sport Cup Optional
Michelin Pilot Sport Cup+ /N-Spec Optional
Pirelli P Zero Corsa System Autocross - Optional /Track - Required
Toyo Proxes RA1 Recommended
Toyo Proxes R888 Optional
Yokohama A048 LTS Optional
Yokohama A048 M Optional
Yokohama A048 MH Optional
