Track car build
You're getting close. When is the shakedown track day?
Shakedown in the Spring. Lots left to do:
Brakes
Suspension setup: corner balance and alignment
Rear LCA bushings need to be swapped to fit coilovers
Bleed all hydraulics
Install DIY trans cooler
Optic Armor windows
Braille battery
Battery cut off
Fire suppression
Finish making new fiberglass hood vent
Front and rear aero
Decals
E85 tune
AIM Datalogger(?)
12 Qt oil pan (if I can find one)
1,066
1,120
Monaca Pa
Where did you source it from if you dont mind me asking? I have only been able to find the 67" readily for sale on the interwebs
Sent from my SM-N960U using Tapatalk
Fred did you make the holes that are on the underside of the trunk bigger than 1/4” for better alignment of the studs for the pedestal?
