Track Tires and Rims
SOLD
THNK YOU
APEX
ET52 Satin Black APEX EC-7
Incl TPSM Sensors with black valve stem
Square set-up
19 x 11
Wrapped with Michelin Pilot Cup 2 tires 305/30R19
Tires used for 1 track day last August (2018)
Includes spacers
Plenty of tire life. Rims in excellent condition.
$1,500.
plus shipping
Located Long Island, NY
You'll need longer studs to accomodate the spacer. This is an extract from Apex's Fitment Guide:
Front & Rear: 19x11” ET52 with 305/30-19 tires
  • Popular fitment.
  • Recommend at least -3 degrees of front camber to prevent poke.
  • Approximately 25mm front spacers required with most suspensions. Aftermarket suspensions with offset struts can reduce spacer thickness. See below.
  • 295/30-19 or 295/35-19 tires can also be used with at least -2.5 degrees of front camber and at least 20mm spacers up front to clear most suspensions. Aftermarket suspensions with offset struts can reduce spacer thickness. See below.
  • 315/30-19 tires can also be used with at least -3 degrees of front camber and at least 25mm spacers up front to clear most suspensions. Aftermarket suspensions with offset struts can reduce spacer thickness. See below.
  • Rear bump stop may need modification to prevent rubbing on the inside. See below.
https://support.apexraceparts.com/h...5526493-S197-Mustang-Wheel-Tire-Fitment-Guide
The wheels are going on a 350R. This is the second set of Apex wheels for the car. No fit issues with 315-705-19’s. Stock studs are longer to fit the centers on the carbon fiber wheels.
Now that I have two set of Apex wheels for the 350R, the original wheels will be stored.
Thanks Richard.
Have you listed your other set?
Good move, since the cost has not come down on the CF rims as many had surmised. The issue we have noticed at our Ford Stores, is if damaged, replacing one seems to take an inordinate amount of time ( we had two GT 350Rs come in over the past few years with rims damaged in transit ). Along with one other damaged rim ( pothole ), would have to agree this is a relatively small number assessment, but in each case we had a long wait for replacement.
I received the wheels and tires on Wednesday. Rimox51 was spot on. Wheels and tires were like new and I strongly recommend Rimox51 to anyone considering buying from him.
He also went out of his way and found a way to ship dock to dock saving me 50%+ on shipping.
Thanks Richard!!
