What makes the Boss 302 a special Mustang....a list.
So I am sure this has probably been done in the past but was thinking there should be a comprehensive list of items that separate the Boss 302 as a special Mustang. I'l give it a go and try to be as comprehensive as possible.
1. It is a Ford developed product and produced by Ford. Not merely a Mustang carrying a name licensed by another company.
2. It parallels Ford history. Produced by Ford and successfully raced as a factory race car.
3. Limited in production to two years with limited production numbers: 2012 there were 3250 standard Boss 302's produced and 767 Laguna Seca's; 2013 there were 3,553 standard Boss 302's produced and 765 Laguna Seca's.
4. Carries a historically significant name in auto sports.
5. Each car is numbered with an identification plaque. Laguna identification starts with a prefix of "LS####". First 50 Laguna's have the LS# match the last four digits of the Vin#. Laguna Seca's also come with special rear badging.
6. The Boss came with an owners kit matched to its Boss.
7. Optional Boss car cover and floor matts
8. Laguna Seca's came with brake ducting in a box for the track.
9. Each LS came with a more aggressive front splitter and rear spoiler for the track and brake ducting in box for the track.
10. The Boss 302 engine was developed specially for the Boss and is a different engine than the 5.0L found non-Boss Mustangs. Upgrades include forged con rods, forged pistons, race main bearings and rod bearings, larger sodium filled exhaust valves, high lift cam, CNC polished heads, exhaust headers and race inspired clutch.
11. Larger radiator and revised plumbing for cooling.
12. Revised baffles in oil pan.
13. Oil cooler.
14. Under body transmission cooler scoop.
15. Finned aluminum differential for cooling.
16. The Boss 302 revs to 7500 rpm.
17. The Boss 302 could be purchased with "Track Key" an industry first that changed the engine parameters to that of the Boss 302R for track use also resulting in a noticeable muscle car lopy idle.
18. Remapped traction control and ESC compared to the Mustang GT to permit more flexibility and performance on the track.
19. Cold air intake.
20. The Boss 302 came with 5 way adjustable dampers front and rear with higher rate coil springs lowering front and rear of car (11 mm front and 1 mm rear). Laguna Seca comes with slightly softer front springs and stiffer rear springs and stiffer dampers.
21. The Boss 302 came with 4 pot Brembo calipers and 14" vented rotors front and 11.8" rotors rear with more aggressive compound pads for the track.
23. Tuned electronic steering with 3 settings.
24. Low expansion brake lines.
25. 6 speed MT.
26. Optional Torsen differential with 3.73 rear. Laguna Seca came standard with Torsen differential and Recaros.
27. 25mm rear sway and stiffer bushings. Laguna Seca came with a 26mm rear sway bar.
28. Quad Exhaust with removable baffle disc for the side exhaust.
29. LS had rear seat delete and X brace for added chassis stiffness.
30. Strut tower brace.
31. Pirelli PZero summer performance tires and Pirelli Corsa tires for the Laguna Seca. Laguna Seca's also received distinctive Laguna Seca wheels over standard "wagon wheel" design.
32. Optional Recaro bucket seats.
33. Distinctive black "Q ball" shift knob.
34. 2012 LS came with distinctive gauge pod on top of dash (oil temp water temp and lap timer).
35. 11 lbs of sound deadening removed.
36. Alcantara covered steering wheel.
37. Boss only color schemes
38. Unique front fascia with blocked off fog lamp opennings
39. Historically accurate livery striping after the 1969 and 1970 Boss 302.
40. Ford produced a 3 part video on the development of Boss.
Feel free to correct add or delete if I got anything wrong.
REVISED 7/7/19 TO REFLECT CORRECTIONS AND ADDITIONS
1,069
Bay Area
7. Inaccurate
8. Inaccurate
21. Not all Boss 302s came with Torsen.
27. Not all Boss 302s came with Recaro seats.
Otherwise pretty much sums most of it up.
The Cover and floor mats were an option.
You could buy a Boss with cloth GT seats with BOSS 302 embroidered in them. And no Torsen. I owed a 2013 #179 and it happened to have absolutely no options.
7. Inaccurate
8. Inaccurate
You could but a Boss with cloth GT seats with BOSS 302 embroidered in them. And no Torsen. I owed a 2013 #179 and it happened to have absolutely no options.
Thanks. I will revise.
7,571
5,305
Don't jump into changes just yet.
7. seems correct. Mats and cover came together in the US separately in Canada. Possible standard on LS.
8. The LS came with the front splitter in a box. Not sure about brake ducting. That may have been a parts counter item.
21. You listed the Torsen as an option, spot on with the standard Boss, stock with the LS.
27. is half correct. you listed the Recaros as an option. Correct on base model and stock with the LS.
Hope this helps. :)
Like the LS splitter he LS came with the brake ducts in a box and were either dealer or owner installed.
1,289
1,113
Philly Metro Area
14. Remapped traction control and ESC compared to the Mustang GT to permit more flexibility and performance on the track.
Is this different than the 2013-2014 Track Pack or Premium GTs that have the Sport Mode AdvanceTrac setting? If so, does anyone know the differences?
11. The "Boss 302 Hi Po" has... and headers that the standard 5.0L did not have.
I believe all the Coyote & Roadrunner engines in Mustangs had the same Tri-Y headers.
Bottom line...When the 2nd generation Boss come out in 2012, it was better equipped for track duty than a Mustang GT but still lacked things to make it a true track warrior.........does such a car exist???????????.......I know the replies are coming......:eek:
Grant: Thanks for posting those links. Very comprehensive listing. I will upgrade my list.
What strikes me is how special the Boss engine is and the effort Ford put in on the entire package while keeping the price point where they did.
What type of things did it lack? Remember it also needed to be street legal also, livable on the street and meet a certain price point.
Actually amazing they stuffed all they did in and kept the price point.
