Not all max summer tires are created equal. The Pirellis are R-comps. I would NOT use them in less than 4O degrees. Pirelli is clear that we should not. At 30 degrees u can crack the rubber.
PeteInCT said:Not all max summer tires are created equal. The Pirellis are R-comps. I would NOT use them in less than 4O degrees. Pirelli is clear that we should not. At 30 degrees u can crack the rubber.
I felt the same thing one of the colder morning here last week. Low 50's and the car hopped away from at light near the house, same day a friend with the LS said the same thing.5 DOT 0 said:I notice diminished grip starting in the mid 50's on the stock Pirelli's.302BOB said:zwede, Are you noticing any loss of grip when the outside temp is below 30 degrees? I was thinking 35/40 degrees would be the cutoff temp for taking my Boss out.
