Crud I was hoping that wasn't the issue. Reading threads now about divorcing the clutch and brake reservoir.It's your Throw out bearing. Clutch and brakes share the same reservoir and brakes get alot hotter than the transmission needs to.
Separating the and having a dedicated reservoir for the clutch will solve the issue usually.
I would divorce it as soon as possible, it isn't cost heavy or super technical, but I doubt you have to worry about replacing the throwout bearing at this point.Crud I was hoping that wasn't the issue. Reading threads now about divorcing the clutch and brake reservoir.
Should I be worried about the bearing now? I haven't noticed anything weird with the transmission.
Thanks guys, seems like this issue isn't talked about enough. I decide to go with the GM reservoir #92065790 and got a master cylinder from a auto car so I won't have to worry about the nipple.
Will update when I get that installed. Besides a lot of flushing any tips to get all these bits out of the system?
Once you separate out the clutch circuit and change to the auto reservoir, a good brake flush should get rid of the gunk out of the brake system. Like someone else mentioned above use dot 3 in the clutch system going forward. The Castrol SRF doesn't seem to play nice with the slave cylinder.Thanks guys, seems like this issue isn't talked about enough. I decide to go with the GM reservoir #92065790 and got a master cylinder from a auto car so I won't have to worry about the nipple.
