WTB: Trailer Toad
760
1,135
TX
Probably a long shot, but am looking for a trailer toad to tow the trailer with an incoming rv. If anyone has a line on a used one, please let me know!
760
1,135
TX
This is the first time seeing one of these. Not sure I would put one on my vehicle. How can this be stable? A get the tongue load sharing. How does this extra hinge not make the trailer unstable?
Using “dollies” on trailers is nothing new. Hell, many mid-America states allow semis to to tow more than one trailer in a similar fashion. There’s nothing about an extra pivot point in the middle would create instability.
Additionally, removing all of the tongue from the RV is a lot more stable and greatly reduces stress on the extended frame. These things are pretty big in the drag racing community.
JDee
Ancient Racer
1,809
2,012
5 miles from Mosport
Can you back that up? I would think not unless it's solid on one side. And even then the binding would be horrendous wouldn't it?
It's kind of like a car dolly and from my understanding you can't back them up either. Tractor trailer trains come in A and B up here, B Trains have 5th wheels on both trailers and a good driver can back one up, A Trains have a dolly converter and God himself can't back them up.
7,557
5,294
States that allow multiple trailers restrict the use to specific highways Because of stability issues. Additional training and certs are required to pull these loads. Why?? Stability, risk etc.. From what I have read, the only requirement to add this equipment to your rig is the cash to do it. Don't get me wrong, I take risks. In this case, I think I would simply buy the right rig to start with.
I did a quick search and found nothing related to testing done on the addition of the "Lift" this unit adds to the back of the RV. Not for me today.
760
1,135
TX
yeah. They have pins to “lock out” the pivoting. Backs up like any normal trailer setup.
Lift?
These are nothing new—whether this specifically or the idea. The physics are proven and they’re much safer to tow with than a standard bumper pull.
7,557
5,294
The oldest reference to the Toad is 18 months old. Its new.
Lift. There are wheels which hold the toad up. When the rear of the RV dips, these wheels then "Lift" the rear of the RV. What effect dose this have on the frame of the RV?
760
1,135
TX
it doesn’t. The toad pivots on the ball just like any normal trailer.
760
1,135
TX
I don’t have any pics of one dealing with a dip, but yes they pivot. It doesn't add more stress to the back. It takes all of the vertical load off the tow rig.
And this specific company has been around for 15 years. The idea much longer. And I've personally been familiar with them for about 5 years. Just never needed my own because I didn't have my own RV at the time.
1,135
TX
Here's an image at the hitch to the tow rig to show how it pivots at the back set of bolts
carver
breaker of wrenches
446
605
ontario
Just my 2 cents. I have over forty years and 100k miles of active trailer towing including everything from 34 ft. travel trailer, dump trailer's, flat bed's, boat trailers, car hauler's, utility trailers and more, all over North America. IMHO a well maintained and properly loaded, secured and balanced trailer with a weight distributing hitch is all you should need. :)
760
1,135
TX
I hear that. I have a similar number of miles under my belt towing (although not the decades :)), and my personal experience shows that if you can get the weight off a rear bumper of an RV, it'll tow better. With a 24ft trailer and a 30ft RV, the axles are just too far apart and the geometry and physics get a bit wonky. These little guys are a great way to make it safer to tow--more stability, less stress, etc.
I wouldn't use only a WD hitch on a longer Class C as that will most definitely lift the rear end and put a lot of stress on the extended frame. The WD hitch I use currently towing the trailer with the truck frequently lifts the rear end of the truck up when going through dips and the rear axle is only 2ft from the hitch. With the 8-10ft distance on the RV, I would be concerned about the extra stress.
carver
breaker of wrenches
446
605
ontario
Absolutely go with your gut. 🙂
I just added up all the cars, trucks, tractors and trailer tires that I still own at 48....yikes that's a lot of rubber to keep inflated.... and I'm suppose to be retired!! o_O and I still want to add slicks for the Boss !
760
1,135
TX
Ha. That's a lot of tires. Get some slicks for that boss. The purple crack will change your life :)
760
1,135
TX
Coworker bought one to pull a 28ft trailer behind his Jeep. He loved it. Now he tows with a Suburban, I'll ask if he wants to sell.
nice! Appreciate it.Once the car is done, I’ll be able to get it all loaded up and test the setup without a toad. Preliminary tests look good, but close to limits which isn’t ideal.
racer47
Still winning after 30+ years
392
497
SE WI
