Blacksheep-1 has me wondering about my suspension setup now...........I have the rear LCA on the lowest hole and the control arm angle is 6.3 degrees (got my accuRemote!).... I will be switching to a 18mm rear bar with 295/30-18 R7's next week. SHould I raise the rear a little and use a higher mounting hole?? I have the 3 hole BMR relo setup. I used to use the middle hole to avoid erratic braking, then I just lowered the rear more and went to the lower hole again. Is their a Ideal angle?? Or may better put... a range??
I let one of my instructors drive the car a few weeks ago and he spinned out on a tight curve..He said I have a very loose rear..... I took offense!! Maybe I got used to too much roll oversteer?
