2012-Boss said:Rick,
I am planning on pulling the spring when I get the car back. I know you still had problems even after you got a new clutch until you pulled the spring. With the light pressure plate on a dual disk clutch, I can understand how the spring could cause an issue.
Steve,
Rev Auto charges $899 for their Stage 1 build. That gets you a rebuild with brass stop, shift pads, fully welded shift forks, and hand dressing / deburring of all gears and synchros. If there is any damage, the cost goes up from there. There shop is only a few miles from the I-95 and 695 interchange, so you wouldn't loose much more than 45 minutes on the way to Summit.
All I will need after I get my car back is a little Blowfish shifter magic.
Is there a link to Rev Auto?
