That is a lot of information flowing from the southern hemisphere to North America. Thank you. Excellent explanation. Great pictures to illustrate your points. The only thing I could not figure out was "stub axle." But, since you mentioned it is slotted and can gain or lose camber by adjusting it, I think it is one of the mounting areas for the knuckle onto the coil over, with the top of the two bolts holding the knuckle onto the coil over being visible in your photograph taken behind the wheel with the coil over set up showing increased room for the 305 between the wheel and the new coil over assembly as compared to the prior, stock set up.
I had no idea that the stock spring perch on the strut interfered so badly. I need to crawl under and look at mine one of these days. My front wheel and tire, from Ford, are 10.5" wide and 305/30R19.
I do have Magneride. It looks like AJ Hartman has a coil over kit that is compatible with Magneride, but the only one I can find is for 15-17. The one Gunslinger55 posted in a screen capture is 2018-2023, but I cannot find it on the site (AJ Hartman's site is not so user friendly to search). What I notice, however, in looking at the photo, is that it uses the stock spring perch, so it is not going to increase clearance at that point. I don't even know if it would work on my 2024 Dark Horse.
I am also not sure what the advantage would be, other than maybe a wider selection of springs.
It looks like the photo you posted is KW, and they have some sort of Magneride compatible setup that does not utilize the stock spring perch. Looking around at Steeda, there are apparently lots of Magneride compatible options. I guess I have a lot of research to do.
Anyway, thank you for making so much effort to explain this. It is appreciated.
