4.6 3 valve blocks
it is mine appreciation they are the same. Some have done the 4 valve but gains where negligible . I dont know how but they did explain. Maybe its the size of the valves and total flow of the stock 4 to the stock 3 . than all the support and PC stuff to make it work.
Maybe a 4 valve ecu and HP tune would make it a banger
1 other thing if I remember correctly front wheel drive Lincoln 4v v8 modular blocks don't work in rear wheel drive cars? Don't remember why or who told me this.
Think 2004 blocks are newmark. Strong block. The ford motorsport aluminator block was latest version.
Tekside will handle 1000hp + after that I know drag racer who broke all main caps off! Yah but turbo was size of attic fan.
Rumor is the Nemak 05+ blocks are the technically stronger than the Tekskid due to extra webbing in stress points.
As for the original question, after late 04 they were all Nemak I believe, and all the same.
There is a dude named Thomas Sanchez in Texas that has a Whippled and sprayed 4.6 3V Nemak block running 1200 hp.
Not sure on boss 302 motors. I bought 2 spare fr500c engines. 1 off dean when I bought car. Other off Jim seafuse.
When roush rebuilt them I'm sure ALL timing components went into scrap pill. And I mean everything other than bare head! and all other things that would be changed in a rebuild.
LOVE to find original motor seal tags!
I do know the later imsa ran boss 302s and R they went to dry sump oiling systems. And cortex rears. And tall gears 4.30 ect
Also if you do a build I would see block you have? Probably wap which is newmark.
Think about stroking it. Either 3.750 or 3.800
Crank. Manley 5.850 rods and matching pistons.
On 92 mm bore will give 5.0 or almost 5.1 liters
Also get rid of all sps bolts use ARP!
Absolutely will be putting a stroker in it
Guy on ebay had kellog 3.800 crank new 4sale cheap 500$
There forged steel. Kellog made the steel 4.6 8 bolt cranks for ford.
Speaking of blocks only, is there a difference between the 06 3v aluminum blocks and 4 valve aluminim.blocks from the same era?
Do you want a ford motorsport aluminator block built short block?
Block is new crank kellog 3.800 stroke. Rods 5.850 manley arp bolt. Pistons manley flat top . Assembled by dessomer racing in NJ.
Fr500c oil pan assembly. Arp everything!
Mmr oil pump.
92mm bore x3.800 stroke just over 5.0 almost 5.1 L
