S197 2008 Mustang GT Build Thread Profile - S197 Mustangs
JMACG
John MacGregor
7
9
New Jersey
This is the Build Thread for 2008 Mustang GT (Rookie!). Reply below.
Hi all!
Good to be on the forum and looking forward to learning more.
I have been browsing endlessly on this forum ever since tracking the car to figure out a better braking solution.
a wealth of information here for sure and thank you.
7,615
5,385
Welcome to the forum and the sport.
I assume you also upgraded the brake fluid along with your other mods. Are your front brakes ducted?
If you are just starting out, I would look at safety and drivers mods first. A good instructor will likely be your best investment in the beginning once the car is safe.
Have you looked at joining NASA or SCCA to get in their programs?
8,627
8,809
Welcome to TMO and bigger brakes, bigger rubber ( and rims ), etc. will go a long way and you already have a nice start in other areas. Feel free to ask on the site if your research leaves you with unanswered questions or if you aren't sure if you found an answer you are comfortable with. Heh, Winter is just around the corner so many on the site need something to do , and helping new " Rookies " ( as you call yourself ) gives us value in life, ha. You will find some folks on here are super knowledgeable and others have similar cars and can often let you know what did or didn't work for them. Are you in Northeastern NJ, as Lime Rock would be closer for you than NJMP - though neither would be a bad drive.
JMACG
John MacGregor
7
9
New Jersey
Thank you for your response and also just to clarify - I was only on the Limerock AutoX course, so not the full circuit. I did the car control clinic with the SCDA and of course, will be with instructors each time out until I get the blessing to move forward.
I just did a full bleed of the system, but did not put in high performance brake fluid (which after reading these forums, I realized was my first mistake). Brakes are not ducted, which I have been looking into and figuring out a good system for street/track '08 S197.
I started looking at NASA and will look into SCCA.
Thank you!
JMACG
John MacGregor
7
9
New Jersey
Thank you for your response Bill and nice to e-meet you. I already appreciate the wonderful resource this forum is and pretty much spent my entire day reading through it all, ha!
Yes, based in Essex county NJ, so have been to Lime Rock a bunch and have never been to NJMP, but have always wanted to go. I was also looking at Palmer Motorsports track which the SCDA program runs at as well.
I had a nice experience with SCDA, so wonder if it's a good way to get the feet wet. But, as you said...bigger brakes & bigger rubber is what I am eyeing. I am a sucker to the Ford Performance marketing and simplicity of fit...so was looking at this: https://performanceparts.ford.com/part/M-2300-S .... but need to save some $$ first.
thanks all!
ChrisM
Mostly harmless.
1,180
1,420
South Carolina
I ran Lime Rock a couple times. That course is no joke. I was lucky enough to do it in a simulator before trying it because going over that hill is disconcerting but being there while the leaves change was a wonderful experience.
Palmer is okay. There are no straights and zero run-off, which makes it a bit hole-puckering.
NJMP is always fun!
SCDA is a good group too. I did Palmer and Lime Rock with them and NJMP with NASA.
JMACG
John MacGregor
7
9
New Jersey
NJMP is always fun!
Yea man, the downhill turn definitely tests your gall!
I am also close to NJMP and have always heard great things, so looking forward to checking that out through NASA.
JMACG
John MacGregor
7
9
New Jersey
Hi all
I’d love to know what people think is the best brake upgrade that still fits the 18"x8.5 OEM Bullitt Wheels. I am looking at a StopTech 14” kit, but would love to know everyone’s thought. Is it necessary? Or are good rotors and pads enough for the 2 events I do a year?
Thank you!
John
1,298
1,306
Lenoir City TN
One of the more popular upgrades for the early S197 cars was to swap over to the OEM 14" 4 piston Brembo set up that was standard on the Boss 302 and an option on the 2011 -2014 cars. The only problem is it will not fit the 2008 Bullitt wheels without a small spacer due to the spoke profile. A friend did the upgrade on his 2008 Bullitt and he needs to run something like a 1/4" spacer to clear the back of the spokes. He tracks the car and said the Brembo's were a big improvement over stock. My 2011 was a Brembo optioned car from the factory so I have no first hand experience moving from stock to Brembo's.
110
154
Olsburg, KS
I can confirm the car EF1 is talking about uses 1/4" spacers. I did an upgrade to using '11-'14 base GT brakes. It uses a different bracket and rotor, but is otherwise the same setup (pads and calipers are the same). It increases the rotor diameter from 12.6" to 13.2". I also added cooling ducts. It's for sure the cheapest upgrade, but there are obviously better braking systems out there. I'm not sure if there's a better system that will let you use the stock Bullitt rims without modification, though.
JMACG
John MacGregor
7
9
New Jersey
Thank you!
I have the 20mm OP spacers, so think I may be able to swing it. Appreciate the feedback.
