2012 Boss motor and 6spd for sale complete wiring harness
2012 302 Boss motor with 6spd transmission 32k miles all wiring harness and gauges bought from parts farm
Steve Mullin
[email protected]
03060
978-9954-1642
$300 security deposit to secure the item for you. This can be paid by Credit card. This deposit is a commitment on the part of the buyer to complete the purchase. This deposit is non refundable. The total balance must be paid within 7 days of the time of deposit of the deposit will be forfeited and the item go back on for resale.
Balance paid by:
Wire Transfer
Bank Check
Company Check
Personal Check
Personal Check and company check will need 3-4 business days to clear before the engine can be shipped.
2012-2013 Ford Mustang Boss 302 "Roadrunner" 5.0 COYOTE ENGINE and getrag mt82 6 speed transmission drivetrain swap kit. This is a 2012 model donor with 32,646 miles.
This engine runs nicely!
This Boss 302 engine is different than the regular 5.0 coyote. This engine comes with 440hp. It has the high flow and great lookingBoss 302 intake manifold, blue coil covers that make it what most regard as the best looking production engine. Not only is it aesthetically appealing, the engine rods and pistons are upgraded in the Boss to be able to withstand upwards of 700-800hp with a power adder!
These are hard to come by!
This Master kit Includes:
  • Complete Ford Mustang Boss 302 5.0 Coyote engine
  • All front engine accessories: pulleys and idlers.
  • AC compressor and belt kit
  • Alternator with belt
  • Engine starter motor
  • Engine top cover and coil covers
  • Exhaust manifolds with front and rear oxygen sensors
  • Engine injector and sensor wiring harness
  • Block plate/dust cover
  • OEM Flywheel
  • OEM clutch and pressure plate kit
  • Hydraulic release bearing
  • MT82 6 speed Getrag manual transmission
  • Transmission stock shifter assembly
  • Driveshaft
  • Drive by wire accelerator pedal
  • Mass air meter
  • Airbox
  • Intake hose
  • ECU/Computer wiring harness
  • Inside dash harness with inside fuse box,
  • Head Light harness with under hood fuse box
  • Body wiring harness back to fuel tank
  • ECU with PATS turned off by The Parts Farm ( antitheft removed)
  • Fuel tank and fuel pump assembly
  • Matching speedometer assembly
  • Steering column with key( or column modified with no key)
Also available:
  • Clutch and brake pedal assembly - $75 included
  • Booster and master cylinder combo $75 included
  • ABS pump assembly $75
  • Steering wheel: included
At no extra charge I include All of the bolts and fasteners that were left over during the engine removal! Try buying those from ford! Probably $1000 worth of hardware!
