Advice on front tire wear New car
That’s a good point but it’s a $3000 set of tires. I will re evaluate. One weekend out of the fronts seems pretty “sad” but no one said this sport was for the timid
Ok the “blister “ is on rear. Yeah they do look terrible a lot of money down the drain in a weekend. You sure i can’t flip them
and keep running? I’ll check the alignment something might be off
You can flip and keep running 3 of them. I don't think that would be a problem. It may act a little different than when running then the original way, but I doubt if it would be all that big of a deal. The tire missing the chunk of rubber needs to be replaced.
It might make sense to replace 2 tires and put the best two used on the 'inside' side of the car at the next track you run. Keep the oddball tire to fix this type of situation in the future.
Ok thanks for the input. So the “blister” is the biggest issue. I have 2 fronts that are better than these so i can mix and match but i agree this thing ate some tires. May or may not run them but it seems like flipping them can extend service life. Just trying to figure out how to keep thins thing on track. Become expensive lol
Yeah, I think you have at least another track day for the fronts.
FWIW, once you kill off the rest of those tires, I would do something different. Like a different brand/tire. One thing, $3k, but regardless of that something with the combo of the car, tire and your driving style is not happy.
More camber no matter what :)
DaveW
It is difficult to find a staggered track tire set up to fit the Dark Horse handling package wheels. I intend to go with an aftermarket square 11" wheel set up eventually. It's just money . . . right? :)
So now we know that -2.25° is not enough.
What are you running for negative camber on the rear?
Did you check the toe? Where is it set front and rear?
It was set to specs in the manual. I need to recheck and or reset as it looks worse so something might have changed..Tine to start cutting and modifying 😉 -2.25/-1.5 rears look pretty good
305 square and be done with it. Don't get hung up on stock tire sizes, it's costing huge amounts of money (and performance). The proper 305 will be faster and better wearing than whatever is happening now.
DaveW
Well these were 305/315 staggered so I am considering 305 square or 315 square
Also since i need to flip tires at least i can see if the slicks fit mount them up and examine….
Thanks for all the comments. I agree burning up $1500 of front tires on a weekend is pretty hard to swallow. Time for something completely different…….
