FORD MUSTANG/BOSS COMPATIBLE GT500 FRONT BRAKE UPGRADE KIT - $1300 (Valhalla)
firefighter120
just an ordinary guy with an extra-ordinary car
BOSS COMPATIBLE FRONT BRAKE UPGRADE KIT.
ORIGINALLY for the 2013-14 SVT GT500 and the 2015 MUSTANG with track pack
FORD 6 piston Brembo, 4 x 15 inch rotors (2 NEW, 2 USED), 2 Goodridge Phantom Series G-Stop Brakelines, 4 GT500 Brake lines (Total 6 Brake lines), Giro Disc custom cut titanium heat shields and R4S compound track pads for the front only and they have plenty of meat.
Except for the 2 brand new rotors, all items are 7/10 condition and I'm being modest here. Brand new the total pkg value with shipping will cost over $2,500.00.
$1,300 for everything and NO SHIPPING. Items will need to be picked up from Westchester, NY.
I guarantee the condition of all parts. Add another $200 and it will be professionally installed by a Ferrari mechanic on your BOSS or compatible Mustang while you watch/wait.
CLICK ON LINK FOR IMAGES
http://newyork.craigslist.org/jsy/pts/5475976716.html
Ref links to parts
https://www.tascaparts.com/index.php?p=cart
http://www.rallysportdirect.com/GoodRidge-12364-CL-G-Stop-S. . .
http://www.frsport.com/Girodisc-TS-1001-Front-Titanium-Brak. . .
http://porterfield-brakes.com/product_info.php. . .
R-4 Full Race Compound
Designed specifically for heavy-duty motorsports. The carbon based semi-metallic R-4 materials allow the pad to absorb tremendous amounts of heat and dissipate it at a very even rate. Carbon kevlar material warms up to race temperature quickly, which is quite helpful during restarts and when track time is limited. When used with cast iron and steel alloy rotors, the R-4 compound requires minimal bed-in period. Throughout the entire heat range, the carbon kevlar material will give extremely consistent modulation and predictability. This is truly the most rotor friendly racing brake pad material ever. Good for road courses, track, rally, vintage racing, autocross, club events or professional racing events.
Goodridge Phantom Series G-Stop Brakeline Kits are constructed from black poly-coated stainless braided PTFE hoses with the highest-grade stainless steel hose ends, banjos and bolts. In addition to providing a more responsive and firm brake pedal by eliminating the "spongy" feel that often accompanies stock rubber brake lines, Phantom Series G-Stop Brakeline Kits provide Goodridge's race-bred, long-term durability and performance.
To ensure proper fit and easy do-it-yourself installation, all necessary hardware is included and matches the vehicle's Original Equipment style used for each application. Additional brackets and hardware are coated for appearance and durability.
By conforming to all requirements of the Federal Motor Vehicle Safety Standard Number 106, Goodridge Phantom Series G-Stop Brakeline Kits are U.S. Department of Transportation certified and T.U.V. approved. All Goodridge Phantom Series G-Stop Brakeline Kits go through a 9-point Quality Assurance testing process that includes measuring tensile strength and the ability to contain line pressure to 3,000 pounds per square inch
680
215
This is a screaming deal.
FYI,
the Goodridge brake line part number you reference (12364) is not designed to work with the 2013-14 GT500 6 piston calipers. The correct part number is 12367. This is a new part number that most vendors may not even know exists. Good luck with the sale....
BT
firefighter120
Oops sorry about that, maybe the ref number is incorrect but the 2 Goodridge brake lines do work/are compatible on the Boss as I checked them on mine.
