- Thread starter
- #21
blacksheep-1
Epic Contributor
Crush sleeves are for manufacturing efficiency. Use the solid spacer and set it up correctly and you are done.
Need to replace a seal or change yokes, no guessing about how tight or loose, put it back together and torque it.
If you use a crush sleeve you can measure the old one , and put the new one in a press and squeeze it down a bit first, generally once the sleeve starts to deform the effort required is reduced.
I did lots of differential repairs in my career and i would rather work on the diff of a garbage truck than these miserable integral carrier diffs.
I agree there. A friend was telling me will set them.up with the sleeve, measure the sleeve and ad .001 to the spacer pack, and from there on out it can be impact gunned on, off, whatever needed. Does that sound like the plan. Yes the 9inch Ford has never been surpassed ( not even by the Dana 60) as
" America's differential"
