Mach 1 handling package build/spring and camber plate part #’s
I’ve probably posted this to exhaustion but I’m finally gonna order the mach 1 handling package springs and camber plates to replace my existing non hp springs in order to complete my 2023 mach 1 non handling package to a hp build, I’ve already added all the other components for the handling package so before I go ahead and order the springs and camber plates I wanted to confirm that the part #’s are correct and indeed will be a direct fit to the 2023 non hp, I wouldn’t mind hearing from anyone who has completed the same build and could share any input,,
I heard to stay away from ford camber plates for good reason but I want to keep it as FP as I can for now,
Front Springs (x2): KR3Z-5310-D
Rear Spring (X1): JR3Z-5560-M
Rear Spring (x1): JR3Z-5560-C
Strut Mount Kit - Adjustable
Part No: KR3Z-3D008-A
Thanks in advance
520
682
Wisconsin
Thanks in advance
5 and 1/2 months later after this post, I had the factory set screws removed from the factory camber plates. This gave enough room to photo the Ford part numbers. Hope this helps but after the long lapse, it may be too late ?? LR3V-18183-AB ( right side passenger)
LR3V-18184-AB (left side driver)
520
682
Wisconsin
For prosperity if someone is looking for info on Ford stock camber plates for the mustang/shelby/darkhorse : .
This set has the part numbers I took for the above post. It says you can get -2.3* camber but my tech at MM got -2.5* !!
