"Power Up Your Boss 302" - Ford Racing Boss 302 Parts List
I didn't see this posted before and thought some of you might like to see it.
Skip past the PDF for some additional parts.............
[pdf]http://www.fordracingparts.com/images/part/high/Ad%20Slick%20PDF%20Folder/mustangpartssheet.pdf[/pdf]
M-5650-A 2005-2013 MUSTANG LOWER CONTROL ARM RELOCATION BRACKET $175.95
M-5638-C MUSTANG BOSS 302S FRONT BUSHING KIT $577.00
M-2005-R MUSTANG FR500C, BOSS 302R/S BRAKE BOOSTER $3,877.00
M-1125-H BOSS 302R/S FRONT BRAKE ROTOR HAT KIT $897.00
M-1125-J BOSS 302R/S 48 VANE FRONT BRAKE ROTOR RING $1,025.00
M-2353-B BOSS 302R ABS MODULE W/ BRACKET $590.00
M-2353-C MUSTANG BOSS 302R/S ABS MODULE $343.00
M-3200-EPAS BOSS 302R ELECTRIC STEERING RACK $1,175.00
[tr][td]
Does anyone know anything about the rotor hats/rings? I am in the market (tomorrow) for rotors and want to make a good choice. I'm sending my last set of DBA 5000 rings and 4000 rears to Diversified Cryogenics for cryo treatment but am going to order another set of 2-piece fronts from somewhere as backups. They look really expensive at roughly $1700 for the pair. Are they cryo treated? What makes them so $pecial?
Those are even more than my Colemans !
If I was going to buy two piece rotors I'd go with floating rotors, just so happens Giro Disk makes two piece floating rotors that are priced competitively at $800.00, not to mention they are made in the USA!
http://www.girodisc.com/Rotors_c_993.html
never mind when you search for it this comes back.....
http://www.latemodelrestoration.com/item/M7512A/2005-10-Mustang-Ford-Racing-Clutch-Fluid-Line-M-7512-A
cloud9 said:
Part #: M-7512-A HP CLUTCH LINE UPGRADE Things that make you go hmmmm
Yikes that's expensive. And it states 05-10 so not sure it fits our cars. Can you say JHR?
http://www.fordracingpartsdirect.com/SearchResults.asp?Search=M-7512-A&Search.x=6&Search.y=9
yeah thats what I thought.
Ford info on the line from their site.......
- Service replacement for the following Mustang race cars: FR500CJ, FR500C, FR500S, BOSS 302R and BOSS 302S
- Fits 2005-2013 Mustang V-6, GT, and Shelby GT500 Mustang with manual transmission
- Upgraded clutch fluid line for high temperature, high performance applications
- Replaces factory plastic line
- Stainless steel hard line with braided stainless steel flex hose reduces line expansion
Whats the JHR part run
I'm curious about this, as well.
I think that the 302R/S use different front calipers, so I would definitely suggest that anyone interested in the Ford Racing 2-piece rotors double check to make sure they'll fit the standard Boss 302 and LS.
George
5 DOT 0 said:
$60.
http://www.hecticparts.com/products/JHR-HIGH-VOLUME-CLUTCH-LINE-AND-FITTING-KIT.html
Seeing how the JHR line is listed as 05-13 perhaps ford racing part fits those same years as well?
http://www.latemodelrestoration.com/item/JHR-8025/Mustang-Jhr-High-Volume-Clutch-Line
either way the JHR line is way way cheaper and probably better but that is just a guess on my part
5 DOT 0 said:
$60.
I tried to order that a few weeks back but there was some goof on their website and I never got it done. Maybe in the future.
ArizonaGT said:
5 DOT 0 said:
$60.
LMR has the line free shipping too
