Will 19x9.5 RTR Wheels with either 275/40 or 275/35 fit on the front of the Boss. The backspacing is 6.5" and offset is +33 mm.
Charcoal look great on the Blaze.darreng505 said:Sure. The first two show the car with the stock springs. The last is after I put the eibach sportlines on though. These are the charcoal RTRs. What do you think?
Lowered
Boss949 said:Any ride change on normal daily driving with the Eibach?
PeteInCT said:The 255/285 F/R ratio doesn't seem out of place, but I can see 255's up front allowing for too much understeer. The car responds very well to some negative camber and wide rubber. It also does well with 18" wheels. I run 285/305 on 35 sidewall.
