Anyone here running an oil cooler on an S197?
I’m getting ready to install a Mishimoto oil cooler on my 2009 GT Club Spec Mustang build, and I’m looking for ideas on the cleanest mounting location and bracket setup.
I’ve found a few pictures online, and it doesn’t look too complicated to fabricate a couple brackets, but I’d like to see what others have actually done before I start making holes and bending metal.
Main things I’m trying to sort out:
If you’ve got pictures of your S197 oil cooler install, bracket setup, hose routing, or lessons learned, I’d appreciate it.
Thanks!
Jeff
- best mounting location on an S197
- airflow without blocking too much radiator/condenser area
- hose routing that stays away from belts, pulleys, steering, and heat
- how people are supporting the cooler
- whether you used rubber isolators/bushings/grommets instead of hard-mounting it
Thanks!
Jeff
