791
1,236
TX
Any thoughts on tires for this build
Pretty sure I don't pass 😜
Right now I'm going with whatever I can get cheapest! ha Picked these up off a local gent that races GTD in IMSA for$100 a tire
I also have a pair of worn A7s from @flyhalf that came on a set of wheels I bought from @flyhalf.
791
1,236
TX
True. Whenever I’m at Road America, I have yet to see someone being sent home early because of sound limits.
I didn't realize RA has sound limits. Should I bring an alternate muffler setup?
791
1,236
TX
Finished up the radiator ducting yesterday. Happy with how it came out! If this works, I'll make out of CF in the future.
Sealed up against the radiator with window sealing foam. I've used this the past with good success. don't worry, it doesn't melt
To secure, I added a couple bolts to my modified k member on the bottom and then a couple into the mount for the upper radiator. Nothing crazy. Just enough to hold it in place
So while this is definitely cobble-fab'd together, it only weights like 2 lbs and my previous experience with making ducting out of this thin AL shows that it works great. So traded a bit of "build" quality for some lightness. Hopefully a CF unit the future will be much higher quality
791
1,236
TX
Any feedback available on any impact on power (positive or negative) after those Ti mufflers??
the Ti mufflers are straight through, so absolutely no impact on power unless you're using restrictive mufflers already. They're basically a light weight way to muffle sound. even the big mufflers won't impact power. They're truly amazing.
Only downside outside of how hard they are to weld is that they don't take the same quantity of heat cycles like stainless. so they can crack after a few years
6,593
8,277
This design has been around forever, what's new is the material. Much much lighter.
Dave_W
1,018
1,326
Ducting looks nice. If you're worried about the thin sheet "oil canning" you can do a poor-man's bead roll by laying it on a sand bag, putting a wooden dowel on top, and hammering the dowel to create a bead. A little bit of curvature from a bead puts a good deal of stiffness into a large sheet.
470
610
Wisconsin
They dont. My car is next level loud and I been there 3 times with it.
My bad, I misinterpreted a rule RA imposes on “their” track days that only allow street legal cars. I’m embarrassed to say something incorrectly as I value my credibility here. It’s rule #18 on attached photo.
1,236
TX
been quietly making progress still. I buttoned up my exhaust project (well, except for the muffler supports that I am waiting on some stainless flat stock to finish).
I'm definitely no master tig welder and this was my first time welding (a shiznit ton) or stainless. We'll see if it holds together. Fortunately, I have mounts placed every 1-2 feet of the system, so there's tons of support in case a weld cracks.
Tire clearance came out pretty good. 1.5 in or more on each side depending on where the wheel is in its travel. Will add heat shield to help with temps. But I suspect at speed, it'll be fine. Might heat soak tho.
System is ARH long tubes, catless midpipes, ARH x pipe into TiCon industries titanium mufflers. Then back to stainless for the exits. V bands are used for mounting and transitioning between the different alloys
I also finished up the pedal box. This was a lot more work than I anticipated. So many lines in a tight space. But happy with how it came out. The footwell box really hides the mess well. HA
Also buttoned up the intake
Going to test the drivetrain tonight. If she rolls and no weirdness, we hit the dyno on Saturday
6,593
8,277
View attachment 95590View attachment 95592View attachment 95593View attachment 95596View attachment 95595
View attachment 95588View attachment 95587
View attachment 95586View attachment 95585
Good progress.
You are overheating the stainless, you only need enough heat to do the job. Turn your machine down and increase the deposition rate (travel speed).
Your welds should be silver to gold to light blue. When you get to dark blue you start cooking the nickel out of the stainless. When you get to grey, its not stainless anymore, its carbon steel now.
If you find yourself welding at half pedal, the heat is too high and that makes it hard to control. You should be near the bottom of the pedal, but not flat out.
Think of a 1000 hp car with skinny tires and 1" of throttle pedal from 0 to 100%...damn hard to control. Now think of a 500 hp car with 5" of throttle pedal....way easier to control.
Smaller rod would help too. I'd use .045 for this project. Keep your tungsten clean and sharp, the second you dip, stop and clean it or it all goes downhill from there.
Also, take the time to get a perfect fit....90% of the battle is getting a good fit up with no gaps. If you are using a collet body consider going to a gas lens, you'll get way better gas coverage.
Make sure you have around 15-18 CFH Argon.
Keep after it you're doing great!
6,593
8,277
Here, I just made this for you:
Hold the cup over the weld as it cools so the oxides don't form over the tail of the weld.
Also don't snap off the pedal when you are done, just taper off and let the gas flow till it stops.
Hope this helps somehow.
6,593
8,277
Curious what this extra little parachute on top is for...what goes in there?
791
1,236
TX
Good progress.
One of the biggest learnings for me with tig has been backing down the heat. This is great feedback. Thanks! I was surprised that your welding example video didn't have any of the blue/purple coloration that seems so common on stainless. Is that evidence it's still overcooked?
Also - this exhaust project really taught me the value of tight fitment. The first side I welded I didn't do a very good job with tight joints and it was exponentially harder. the other side I through pieces away that didn't fit well and it went MUCH smoother.
Like so many other things, most of it is in the prep work and I'm learning that's a big difference between a good fabricator and a n00b like me
791
1,236
TX
Air cleaners for the intake. Will be hidden behind a blocked out grill. It'll make more sense once I post what I'm doing with the bumper
6,593
8,277
Yes, there is a color band that starts with silver and gets darker with heat ending up with grey.
You are doing so much stuff and learning a ton its fun for me to watch as you go.
Don't get discouraged you are killing it.
6,593
8,277
Yeah yeah yeah yeah....THATS what goes in there.....I was thinking:
"Its not for an oil cooler.....he has EPAS so no power steering cooler either...what could possible go in there?
AIR CLEANERS!
