350 Wiring Issues
73
122
Corona, Ca
I'm at the point were I need to wire up the dash and get the systems working again. I think I have all of the grounds attached and necessary modules attached. All i'm getting is the head lights go on temporarily. Nothing else works. What module activates the push start button? I can't seem to get the car to turn on at all. Any help is much appreciated.
I don’t know the answer to this but I understand that the modules need to be paired to each-other. Is all the wiring and modules (pcm, BCM, abs, etc) from the 350? Is anything with a chip in it still from the Ecoboost donor car?
Also I think you should probably get Forscan for diagnostic purposes (you can check all the codes on the canbus network to figure out why only headlights) but also potentially use it for reprogramming some of the modules or as-built data. I’m coyote swapping my Ecoboost and while I’m a bit behind you still it seems Forscan will be nearly a necessity for diagnosing and completing the swap.
73
122
Corona, Ca
Thanks that is what I needed to know. I replaced everything from the 350. I'll get the scanner and see what is going on. I know on Jeep you need to program the fuse box to the after replacement. Also BMWs are really CANBUS sensistive.
I found a ground that I did not connect and that resolved the light issues but it still doesn't turn on. Thanks for the help.
Sounds good, please keep us updated. These cars are very Canbus heavy too. The start stop button is on one of the canbus networks for example.
There are a few guys on here that know Forscan fairly well it seems, hopefully they will chime in.
Do you have the keys from the 350 as well?
73
122
Corona, Ca
Yes, I have the key. I'm getting closer now at least I get the message on the dash screen NO KEY DETECTED. Now I need to find the security receiver and reinstall it. It is in one of the many boxes of parts from two cars!
73
122
Corona, Ca
Found the Receiver and plugged it in and the car turns on. Now I just need to work thru all of the door and lid sensors. I have abandon the MR so I will need to program it out.
I'm getting
P06E9 DTC No Start​
Code on my Snap On Modis.
On Jeeps we have to program a new fuse box to talk to the Jeep. Since I replaced the engine bay harness and fuse box. On the S550 is that required as well?
7,560
5,294
73
122
Corona, Ca
I found this on another site. Hope this is helpful.
Check the pdf in this linked thread; any time there is major engine work or trans work performed on the S550 5.0, the Dealer Service Tech (or DIYer) is supposed to do a crank relearn procedure.
https://www.mustang6g.com/forums/th...s-weird-hesitation.125119/page-2#post-2679084
Also check this link if you have an gauge for crank relearn:
https://www.mustang6g.com/forums/threads/new-clutch-dtc-and-shudders.148583/#post-3035678
I was just reading that thread on M6. Thanks!
