GT350 Oil cooling issues on track
Hi folks, I ran into oil cooling issues at my last track day. Oil temps rose to 290+ degrees, putting the car into a temporary limp mode until the temps came down. The last few sessions I tried short shifting, which helped. I know from reading similar threads that this is pretty normal for this car/engine, but I’m wondering if anyone knows of a mod or upgrade that will take care of the issue. I would like to be able to focus on pushing myself and the car on track rather than short shifting and worrying about oil temps. Any help would be greatly appreciated.
For reference:
- 2018 GT350
- powertrain/drivetrain is stock
- all other temps were fine
- oil change right before the track day with Ford Motorcraft 5w-50
- no other known issues
1,250
1,244
In the V6L
For reference:
- 2018 GT350
It would be helpful to know what track and what weather - outside temps, etc. The factory cooling is pretty good on the GT350, so it's rare to get one that hot. It's possible you need more cooling, but it's also possible that the existing cooling isn't working right.
dang, I meant to add that info.
Track: Heartland Park Topeka
Weather: Sunny
Outside Temp:
- Morning session was in the 60s
- late Morning was in the 90s
Both sessions had this issue.
501
550
Snowy North
Have you ever inspected/cleaned the surfaces of your heat exchangers? Might be covered in crud, bugs, pickup?
899
546
Actually, the OPs experience is not unusual. The factory GT350 oil cooler is not sufficient if you really start working the car, especially in warmer weather. Basically, you need a Setrab 960 for 5.2L motors and possibly fabricated ducting. Take a look at what is in the FP350 - a Setrab 960 with ducting, not the OEM GT350 cooler.
196
301
75024
Check for fine debris in the coolers, mine had to be picked/blown out pretty well after a season or so. It should not get that high even running hard in the 60 degree range. I'm in TX and the worst I've seen is 260-270, and my track has lots of hang at redline in 3rd and hard pulls in 4th.
