any body interested in a clutch group buy?
this would be for the exedy clutch.
i would have to call and get pricing down but it would be similar to what i did for the forum members on the driveshafts.
just throwing this out there. if there is interest ill clear it with the forum boss.
steve-o
Go for it.
I'm still holding out hope that Ford will have a solution to my clutch/shifting problems but that hope is fading fast.
steve-o
I'd like to get a few track days in this season and see if I have any more issues. Any more failures and I'm in.
so be it.
ill get some numbers for the kits.
i would not hold out for ford or this made in turkey clutch that installed in these cars...lo
steve-o
PeteInCT
2,848
14
Steve - as we discussed, put me on that list. Based on any savings I may just get one and hold on to it until I need it.
-Pete
PS: Your harnesses are going out Monday from Boston. They have been upgraded to Hybrid-II's. I'll get back to you with where/how to return the Profi-II's.
Rehagen has Exedy clutches around 50% off, details: http://www.s197forum.com/forum/showthread.php?t=98473 Call before you order; Scott went over the fitments for the MT82 in another thread, I can't remember if we are 26 spline or 23 spline.
Justin
MT-82 is 23 I am pretty sure.
ill k now prices on monday. if i cant get this goping for less than that ill not waste our time.
ill let every one know soon what i can get this done for
here are our options on this.
exedy clutches.
i can do the stage 1 or stage 2 or the hyper multi's
prices vary on each one but not by much. until you get into that hyper one, and its kinda pricey.
i can also do the act clutches.
that being said, which one would you like if you wanted one from act?
fm13-sps o a fm13-spg6 or a fm13-spr6
the r is for race. s is for the street cars and the g is a hybred for the street and race.
steve
just for giggles here are some numbers right now.
stage 2 6 pad street/race clutch for the boss with a lightweight flywheel.
rated for 650 ft pounds torque.
flywheel is 15 pounds and the clutch is 11 inches in diameter.
looking at 540 bucks.
the engagement is A stock to low pedal feel; aggressive engagement with stock to low to moderate gear rattle
this is a act clutch. there are a lot of different systems from act for the cars.
they do.
i am thinking there the same parts you have in fact.
if i remember right they make the same clutch you have
i can do those even. but that price is going to be higher.
and again, without input from some one act has alot of clutches for these cars. i need to know what people want so i can get it going.
not every one can afford that high dollar system. nor need it. i think the sateg one system would be fine for the majority of people. or the stage two.
