- 6,415
- 8,323
Re: Boss 302 Advance Road Race setup thread
The sidewall indicators (the distance between the indicators and the wear marks are sometimes called "chicken strips" BTW) are another tool to use, and in a perfect world the temps would match across the tire and at the same time the wear would come exactly up to the indicators..but we don't live there often, so IMO the temps would take precedence, but it is another reference, and baring the use of the pyrometers , probably a good one.
Not uncommon, this is why tires are usually covered in the pits with blankets, or left in the shade, however, once the pressures are set (at the right temps) does it really matter if one side is higher than the other? HhMMMMMMMMMMmm chew on that one. ???
Let me ninja-edit and add to this for the sake of discussion, you have a setup on the car, you know that in the last session the pressure was...28 cold when you went out and 41 hot when in,(for simplicity's sake they're all the same) the car is now on the grid. one side is in the shade. The pressure is 28 in the shade and 29.5 in the sun..what do you do about that?
Another thing I heard was to adjust pressure until the tire rolls over onto the indicators. Is there anything to this approach? Or is this superseded by measuring temps with a pyrometer? Turns out that running 35 PSI front and 37 PSI rear [hot measured at the paddock] gets my Nitto NT-01 275F / 305R tires to roll right to the indicators, so this was my target hot pressure for my last event at VIR. Held very steady throughout weekend.
I was told to set pressures hot and then I read them cold before the next session to set a baseline for 1st sessions on subsequent days. I always write down the air temp but don't have a way to measure tire temp [yet]. I've noticed as much as 1.5 psi difference just because 1 side of the car was getting sunlight and the other side was in the shade.
