Boss 302 Advance Road Race Tire setup thread
6,421
8,328
Re: Boss 302 Advance Road Race setup thread
If you don't or can't use nitrogen then buy a couple (or 3) of these and hook them inline from your air compressor (segregate the tire hose from the usual stuff) and use it to fill up your air tanks for the races.
steveespo said:
In reference to the small rear bar, I changed to the 18mm bar but thus far have only run one wet weekend at Summit Point WVa. In the wet more compliance helped grip. I feel wet or dry the reduced roll stiffness will help the rear axle be more compliant and load the outside tire during cornering. With stock Boss or even bigger LS rear bar the rear seamed to not plant during cornering and exit, the soft bar made it easier for me to feel what the rear tires were doing and I could control wheelspin that I was getting coming off of Turn 10 onto the main straight. Under braking I found no adverse effects, in the wet braking from 127 to 40 mph, in the dry it would be 140 to 60 or so. No rear wiggle or additional dive.
I will be running a hopefully dry day at Lime Rock on Nov 16 and will try and get some feedback on tire temps and performance. I am hoping to see a temperature increase at the rear indicating the rear tires are working more with the soft setting, taking some of the load off the front.
Maybe I have it wrong but that's my initial impression.
The temps will be about 40 F as long as its dry. Its gonna be cold.
Getting back to running without a rear sway bar, I was at the track this weekend and talked for a while about this with some great techs that support multiple cars at events here. What they said is how I was thinking the issue, the smaller you make the rear bar the more push or under-steer you get. Then once you remove it completely it goes the opposite way and adds lots of over-steer. The easy way they explained this to me was that with no bar the wheels are working independently and that does make for a wild ride.
While I still may look to a smaller rear bar in the future I still have no plans to remove it. Even with coilovers it sounds like something I don't yet have the skills for.
6,421
8,328
IMO it depends on what you call "lots" the idea here is to continually go down on the bar size, make shock adjustments and sort of "sneak up" on what you're trying to do. To go from one extreme to no bar would not be a good idea, but to go from a "micro" bar to none is really not that big of a step because you'll be following the change with shock/spring adjustments.
Thanks for this, I am not an expert and have not actually tried running without the rear bar. You forgot one thing, the piles of expensive bars and springs in the storage room. I would like to experiment more but there are other things I need first, like a wing.
Right now the car hooks up well with the 18MM bar and the springs work at very different tracks here. I am sure there is a better combo for Sebring vs. Daytona but honestly the driver mod is needed more before fine tuning. Still, I will be interested to see what the Bosses will be running this year at these tracks.
Rob, forgot to mention that I tried different settings with the front bar this weekend. I had the bar in the middle and full soft with the Rolex 285's. I also ran the Conti's 275 squared with the bar on full firm and in the middle. So the only settings I did not try was full soft squared and full firm on the staggered but there is not need to even try that one.
Once again just like PBIR I felt little difference. I was expecting to fell a difference at least in the full soft setting but did not even notice the change. I do plan to try out a full soft with the 275's all around and hope to feel it. I am guessing it will be a tad loose but very controllable.
6,421
8,328
OK, let me think about this..it's been my experience when you make a change and nothing is happening then it's being cancelled out by something else..say for example the sway bar change is being negated by a too stiff front suspension. that's just an example. I don't remember, do you have coil overs on the front? You can try to soften the front shocks to let the bar work..just a thought.
Back in the day (1970s) there were 2 schools of thought on this one (Guldstrand) felt that all the parts should work together, shocks, springs, bars. The other (Mitchell) thought that you should run the softest spring /shock setting possible (stiffer on smooth track, softer on bumpy) and then use the bars to control the roll. In truth, I think most guys start out with the Mitchell method and as they dial the car in end up with the Guldstrand style.
Yes on the coilovers, Koni's all around weighed and balanced. It does need to be re-weighed as some changes were made, AC delete etc and the fronts had to be adjusted since they were hitting the control arms. I think I have some ability to fell changes made to the car, like the smaller rear bar, but I am not driving on the edge all the time and may not be able to feel smaller changes like the front bar.
6,421
8,328
I wonder, and this is just a shot in the dark, if the front end is bottoming out and this is negating any chassis adjustments?
Rob, this did happen, I wrote about it here but I don't think I worded it well. The sway bar was making contact with the control arm and we need to adjust the coilover a little. This messed with the corner weight but I have not had it on the scales again to see how much. This is one of those things I keep forgetting to do but I need to repaint the marks on the control arm to see if it is still happening.
Rob
I just unloaded my car from this weekend a few hours ago and did not check the control arm to see if the sway bar was hitting it. I can say I felt the car was a little too loose at the turn exits and felt unstable in the long sweepers (turn 1, 17, Big Bend, Bischops Bend and worst of all the right and left high speed turns fter exiting the Hairpin) so we set the bar to the middle from the rear setting. Was running front 275's non GT-I for two sessions then GT-I's after that, rears were GT-O day 1 and day 2 the new G6000 285's from the GTD class.
Saturday slower laps - first with last year's CTSCC compound front 275 and GTO 285 rear that I was told to run at 28 hot but started higher to be safe. Aiming at 39 hot front and 31 hot rear. Started lf 27 rf 27.5 lr 22 rr 22
LF RF
39 39
LF 158 156 156 RF 154 148 144
LR RR
31 31
160 164 168 RR 168 173 167
session 2 Sat
LF RF
39 39
LR RR
31 31
SESSION 3 CHANGED TO CTSCC 275 GT-I compound in front - same rears
LF RF
40 40 REDUCED BY 1 POUND
LR RR
32 33 REDUCED BUT DON'T REMEMBER HOW MUCH
SESSION 4
LF RF
36 36.5 WAS TAKEN IN PADDOCK SO LOWER NUMBER AFTER COOLING OFF
LR RR
28.5 28 LR was corded or better said was worn passed the wear holes, which added to a bad turn in on 15 lead to a spin
DAY TWO After the first session I started running better Ran GT-I front 275's and the new TUDOR 285 G6000 compound on rear all day
Session 1
LF RF
39 39 Left front tire completely corded inside and out, changed both fronts to same compound but increased the pressure to am at 40-41 because of the cording
LR RR
29 29.5 WAS AIMING FOR 28 IN REAR REDUCED PRESSURE
SESSION 2
LF RF
42.5 41 REDUCED BOTH FRONT PRESURES, looking for 40
LR RR
29 29
LR 149 154 154 RR 149 159 158 Taken after cool down lap.
SESSION 3
LF RF
40 40
LR RR
29 29 Very close to the pressure we aimed for and left alone for the last session. No data last session.
So again my apologizes to John, Gary and others running the Rolex tires as the pressure is way different then I had thought. Here is the 275 GT-I that corded in one session, I was running hard and fast, beat my all time low at Sebring by more then 4 seconds.
New G6000 compound wear marks, hard to see but nice even wear:
the starting pressure was so low it wore the paint lettering off just driving to the pits and not from rollover. The tires looked as if they were flat.
and the 275's wear day two at 40 psi
6,421
8,328
I've seen that before when using lots of camber or when inflation is too low, it's where the tire tread is bonded to the tire carcass.
I'll get back to you guys on the rest..
Also found a great article on nitrogen vs air
Although nitrogen has been used for years in the tires of military aircraft, F1 cars, and fleet trucks, its use in passenger car tires has been getting a lot of press lately. If you research the subject, you'll find that much of the information is intended for just that: passenger car tires. As such, many of the differences between nitrogen and air are not relevant to racers. However, there are several differences that are of great importance and should be considered with regard to racing.
http://www.vscda.org/cars/expert__racetireinflation.php
I was concerned about how the rubber seemed to be pealing off on the inside. Spoke with Jon and he assured me it was normal. He has expressed concern about how long I use them but also said since my car is heavier then the GA Boss and I have been pushing a littler harder so this will happen. This is the first time I have corded a 275 in a long while, from before I learned proper inflation on these tires.
Below is the lest set of GT-I fronts used from the picture above except cleaned up the Blacksheep way.
FWIW if anyone is following this these are cold pressures when I got home, you can compare them to the notes above and where the hot pressure were taken off. First listing below if the last set used:
LF RF CTSCC GT-I
27 28
LR RR TUTOR G6000
18 20
LF RF
27 27
LR RR ROLEX GT
17 18
LF RF
26 28 CTSCC NON GT-I (one day since use)
Although teams have not seen a difference in wear I have noticed the older non GT-I's last a lot longer.
Wanted to bump this back up again for a little more discussion about front suspension setups. I want to do what I can with the macpherson strut suspension despite its limitations - especially with regard to camber gain.
First, I want to ask about any individual setups that have been changed or adjusted with the intent to modify camber gain rates.
Second, I'd like ask any of the guys who have pictures of or access to any of the professionally raced cars about what they have modified in the front geometry wise.
On the front, I currently have P springs, MM CC plates, Eibach camber bolts and LS struts. I have the strut angle of inclination and caster set to maximum positions on the CC plates and use the camber bolts to reduce the static negative camber to -1.5*. My goal is to make more use of the inside front tire than I was without the CC plates and -2.5* of static camber with only the camber bolts. So in theory, I'm getting a bit more compression camber gain with the increased strut angle, plus some from steering input camber from both the increased caster and strut angle. Front grip has been way better in low speed turns at Streets of Willow, and should be better in higher speed sweepers. Tire wear was good despite the reduced static camber. Was hoping to test that at Chuckwalla this weekend, but the whole family has colds at the moment. :( Anyway, my only other planned geometry changes are tall ball joints for more camber gain and higher roll center, but am considering adjustable front LCAs for a bit more caster.
Comments or criticism on the direction I'm going?
6,421
8,328
Keep in mind when I talk suspensions it's from the CTSCC point of view, and their rules are very restrictive, that being said IMO you won't need those extra tall ball joints and the amount of camber you have sounds close. (-2.5) Run the Ford blue bar in the center setting, 18mm or no rear bar about 550-625 in fronts with coil overs and 275 -350 in the rear. The camber sounds about right do all the rest with shock adjustments. That's as close as I'm going to tell you, and a lot of that depends on the track.
344
steveespo said:
I would like to start a serious BMO setup/tire management thread and ask that you all help us understand some of these nuances to improve performance. i know a lot is tire or chassis specific but I am not adverse to copying a race setup (or copying anything for that matter ;D) but also understand why it works. There is some good info out there but I would like to follow what the Continental GS class cars are doing because their type of road racing is closest to what I am doing during my track day events i.e. 30 minute Sprints as parts of a longer overall race day.
Plan on changing to a Eibach R2 coil over setup this winter to allow fine tuning of spring rates, ride heights and both compression and rebound damping. Want to get a feel for what rates the pros run on the tracks we all run on too, so Lime Rock, Watkins Glen, Road America, Laguna Seca, Mid Ohio, VIR, Barber, NJMP, Daytona are all on the list and info is out there, we just have to ask questions and milk our resources. This is a very mature forum which I am proud to be a part of so I think we will be taken seriously by the pros who we all talk to or do business with. They may not give out all the secrets but I bet we can get pointed in the right direction.
All input is welcome so the experienced Boss/Mustang shoes like Gary, Yellow Boss, JScheirer (hope I spelled it right) Pete, some guy named mwilson7, roketman, Arizona GT, MCM and all the others lets get it started.
check out cortex racing
they have a setup to run 315 x18 square
Filip is very knowledgable & a great guy
www.cortexracing.com
