Here is some test data, it was run on Motorcraft 5w/50 and Driven 5w30 a few years ago. I could not find data for Driven 5w50
Wear protection ranking are:
• Over 105,000 psi = INCREDIBLE wear protection
90,000 to 105,000 psi = OUTSTANDING wear protection
75,000 to 90,000 psi = GOOD wear protection
60,000 to 75,000 psi = MODEST wear protection
Below 60,000 psi = UNDESIRABLE wear protection
5W30 Joe Gibbs Driven LS30 Performance Motor Oil, synthetic = 104,487 psi
The bottle says it is formulated specifically for high output GM LS engines, and that no ZDDP or additives required. This is by far, the best performing Joe Gibbs oil I’ve ever tested. It is at the very top of the OUTSTANDING wear protection category, and fell just short of the INCREDIBLE wear protection category.
zinc = 1610 ppm
phosphorus = 1496 ppm
moly = 0 ppm
calcium = 3515 ppm
TBN = 8.8
This oil contains sufficient amounts of the components required (detergent, acid neutralizer, etc) for normal change intervals in street driven vehicles. But, it has way too much zinc/phos for use in cat equipped vehicles. However, it is well suited for Race Cars, Street Hotrods and Classic cars.
5W50 Motorcraft, API SN synthetic = 103,517 psi
zinc = 606 ppm
phosphorus = 742 ppm
moly = 28 ppm
calcium = 1,710 ppm
TBN = 6.7
Interesting that some of the so called special racing oils like Royal Purple scored low, about 75000 psi
