Braille Battery
1,022
100
Texas
http://www.amazon.com/Braille-Battery-B14115-Lightweight-Racing/dp/B004DDI1AG/ref=sr_1_1?s=automotive&ie=UTF8&qid=1436635191&sr=1-1&keywords=b14115
Will this battery work as a replacement in our cars? I saw on another forum someone was using this in their GT. Thanks
302 Hi Pro
2,009
441
Southeast
Adam:
If it does, don't forget the new battery hold down kit with the right sized top bracket. Is this a battery that you can also mount horizontally? Looks like a nice weight savings.
Good luck,
Dave
2HP
PS: I purchased a new 8 drawer side box for my tool box, I needed the additional deep drawers to store my special tools in Pelican boxes! Was looking at that again this morning, it's so nice. Thanks again,
Dave
1,022
100
Texas
I emailed Braille and they got back to me pretty quick with some more questions on what my particular application would be. I am looking to lose some weight up front but I also want a dependable battery. I also found a kit from Braille to tie the battery since it is so much smaller.
Thanks for the response Dave. After I ordered that Pelican case for you I ordered another one for myself because I liked it so much.
Adam
I am using the Braille B129, slightly less amps and weight and it works great. I am on year two with it and no issues. Guessing the one you are looking at will also work. The only negative is that the reserve amps are low and thus I place it a charger if not using the car for a couple of days. Not a big deal for me as the car is basically just for track use.
1,022
100
Texas
What did you use to mount it in the battery tray?
1,022
100
Texas
I was looking at something like this:
http://www.amazon.com/dp/B005P9772K/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=2I9ZC61VUTBNV&coliid=I3K96RDYAADYWE
or
http://www.amazon.com/Braille-Battery-1218-Aluminum-Horizontal/dp/B004DDNFWU/ref=sr_1_2?s=automotive&ie=UTF8&qid=1436761474&sr=1-2&keywords=b129
7,557
5,293
Curious if the braille battery and a circulation pump for trans fluid would fit in the same space as the stock battery?
Anyone with the Braille battery feel there is room for a small pump as well as the battery?
or
I used the first option with the J hooks and drilled holes into the existing battery box for the j hooks to attach to. Has worked well and has passed tech inspections.
