I recently replaced diff fluid and after a hard day at the track it puked some, what I wanted to know is should I replace that fluid since it was minimal or should it be left out as it got rid of the extra-ish fluid.
Brandon302 said:I recently replaced diff fluid and after a hard day at the track it puked some, what I wanted to know is should I replace that fluid since it was minimal or should it be left out as it got rid of the extra-ish fluid.
Grant 302 said:My guess is that it was over filled. Where is your breather cap?
Didn't somebody here fill to the upper one on the diff cover once? Wouldn't be surprised if several people have done it.PeteInCT said:1) You need an expansion tank, everyone does...
2) Check the level. It's the fitting towards the engine, not the rear one.
-Pete
Brandon302 said:Breather cap is on the back of the dif close to the top.
TMSBOSS said:I thought the rear diff was filled to the bottom of the front hole? Trans is below.
Brandon302 said:I filled it using the rear hole, assuming that was the fill hole. It did end up puking a little fluid out when filling, so it may have also been over full at the track.
Grant 302 said:Did you use more than 2 quarts for the fill? You only need 1.7, IIRC.
06mach1 said:The proper fill level is like Grant stated, 1/4" to 9/16" below, NOT to the bottom of the hole. I have never had mine overflow on the track. I also have Fords turkey baster on top of my cover just in case though.
