Using a test sample is excellent advice.KK1826 said:5 DOT 0 said:I had a shop install mine. While not official I've heard some shops use an impact gun but you need to be very careful. If you go too tight you could snap off the top of the strut.
yep
Just use the adjustable setting on the impact gun to set it to the approx ft lb
To do this you need to work on a sample with a tourque wrench then adj the gun to suit.
Make sure to work it out with a test sample first.
That is how i did mine.
