Hi,
I've been eating up the inside of the front wheels really fast - I got 4-5 mm tread on the outer half of the tire and nothing left on the inner shoulder. Allegedly, there was an alignment measurement done in CA before and after Steeda Boss springs were fitted. It said nothing changed; -1° camber and 0° toe.
So I made a rudimentary measurement using string, L-square, spirit level and measuring tape. Got -1.7° camber and -0.4° toe (yes, I'm fast into corners... ;-)
Just ordered CC plates to be able to have different settings for track and street. I will have a new alignment done by professionals once they are installed.
I have seen the Boss alignment spec; caster 7.0° ± 0.75° camber -0.95° ± 0.75° and toe 0.20° ± 0.20°.
From what I've heard, more negative camber will automatically mean more toe out. This true?
If so, I am thinking I could go for the following setup:
Street: caster 7.0°, camber -0,5° and toe 0°
Track: caster 7.0°, camber -1,7° (I read that the Steeda Boss springs will not allow more camber) and toe will be somewhat out.
- Any ideas on what toe out will be in the race setup?
- Am I doing this the right way around? I could do it the other way around; set Track toe to -0.2° and see what the Street toe turns out to be. But I don't want the excessive tread wear I currently have.
- Are these settings any good?
Thanks//Swede
Thanks//Swede
