Full Tilt Boogie GT350 Brake Upgrade for S197 Mustangs
VoodooBoss
Rick
captdistraction
GrumpyRacer
WHAT!
I can't wait to find out how they got the rotors to work on a S197 car.
my guess is its all in the spindle to caliper adapter, maybe a spacer under the rotor but since you have to build an adapter anyways, might as well position it straight up
Good point, that's probably what it is.
So the GT350R front brake upgrade kit is $1,800 on there site so I would imagine this kit is going to be in that ball park.
captdistraction
GrumpyRacer
The thing I've always wondered about radial mount calipers on bolt-on spindles is: why is there an advantage?
You still have to mount an adapter which is essentially bolted onto the spindle. Perhaps different material selection offers a benefit? I'd wonder if it was negated by having multiple pieces and fasteners versus being all part of the same casting or forging.
VoodooBoss
Rick
@captdistraction there's no advantage from a shaving time off your laps but IMO the ease of use is worth the price of admission alone. Once the wheel is removed you can have the caliper off in a minute with no swearing! The problem with the stock setup and mounting to the spindle is you're screwing a steel bolt into cast aluminum. That's fine if you're only removing the caliper once every 50,000 miles but as we all know using them for track work they get removed way more frequently. Same applies when using the stock GT350 setup. Many of us installed steel studs which significantly reduces the potential for damaging the threads in the rather expensive aluminum knuckle on the 350. Once you've used a radial mount setup it's hard to go back.
The connection you mention is not an issue. There isn't a lot of stress on those connection points.
Another advantage of going with a race setup, which mostly come in radial mount, is they are forged calipers vs cast. Not only will the forged be stronger and flex less a forged caliper is better at dissipating heat.
Too bad the GT350 doesn't have radial mount rear calipers as the stock setup is a PITA to service with the parking brake being in the middle of the rotor.
Can you bolt up a s550/GT350 spindle to a s197 and have all s197 hardware bolt up and achieve the correct suspension geometry?
captdistraction
GrumpyRacer
Sort of. You can bolt the crossmember, arms, spindle, and struts. You would have to convert the strut tops with some sort
Of custom camber plate but a lot of it will surprisingly bolt up. Don’t quote me on the geometry being perfect but the chassis do use common mounting points
Has anyone actually done this conversion?
I actually have everything but the adaptor and the rotors are priced right.
