GT350R hub replacement options for heavy track use?
1,937
2,037
Michigan
@tracktardicus The front hubs are bullet proof. Rear Hubs are a maintenance item. Studs are fine, but bearings will get noisy/loose after extended track time. If you have an R, buy the stock 350 hubs and use/reuse ARP studs -- it's way cheaper.
4,023
1,971
No greater expert on tracking GT350s than Black Boss. Factory hubs are very strong. Keep a new set as spares and change when they become loose. Also keep watch on rear axle nut torque, they sometimes become loose and accelerate wear on the rear hubs.
4,023
1,971
Last time I was at Griggs Racing they offered an upgraded hub bearing package that was supposed to last a lifetime. Might want to give them a shout as well to see if that is an option for you.
Must be something in a ceramic bearing package. They really are the way to if you can afford them to be fabricated to your needs.
