Thank you for the diagrams. Unfortunately I wasn't able to use the the CAN data from the car to get the inputs the transmission controller needs, so I had to go analog. I've got the TPS and MAP sensor working perfectly just need RPM. I tried using a coil pack wire for RPM but the controller was having a hard time reading actual RPM, It would fluctuate all over the place randomly. I'm leaning towards pulling rpm from a camshaft position sensor. Any advice for trying to make this work?
Sadly, but can’t help with the analog area. In case you still have any hope in CAN messages, here’s my discovery of them: https://github.com/v-ivanyshyn/parse_can_logs/blob/master/Ford CAN IDs Summary.mdThank you for the diagrams. Unfortunately I wasn't able to use the the CAN data from the car to get the inputs the transmission controller needs, so I had to go analog. I've got the TPS and MAP sensor working perfectly just need RPM. I tried using a coil pack wire for RPM but the controller was having a hard time reading actual RPM, It would fluctuate all over the place randomly. I'm leaning towards pulling rpm from a camshaft position sensor. Any advice for trying to make this work?
Is RPM value only available on HS3 or can it be viewed from HS1as well?Sadly, but can’t help with the analog area. In case you still have any hope in CAN messages, here’s my discovery of them: https://github.com/v-ivanyshyn/parse_can_logs/blob/master/Ford CAN IDs Summary.md
On ID 0x204 it's on both HS1 and HS3. On 0x109 it's on HS3 only.Is RPM value only available on HS3 or can it be viewed from HS1as well?
I'll have to speak with the support staff for my controller to see if the can incorporate these values or not. You've been a great deal of help I'll keep you posted weather this works or not.On ID 0x204 it's on both HS1 and HS3. On 0x109 it's on HS3 only.
So, if you take ID 0x204, the formula would be (byte3 * 256 + byte4) * 2. On that screenshot you posted above it looks like they accept two bytes for RPM in the same way, but still unclear how to multiply it by 2 according to the formula.
Are these values going to be the same for a manual GT? I noticed the github article you made was for a 6r80. My car orignally was a 6 speed manual and has the stock ecuOn ID 0x204 it's on both HS1 and HS3. On 0x109 it's on HS3 only.
Yes. As a rule the values under the same CAN ID are the same across all the variants of the car. In general, in automatic version may be present some IDs dedicated to it's gearbox, but it would be some edge cases, as far as for other specific features depending on the car configuration...Are these values going to be the same for a manual GT? I noticed the github article you made was for a 6r80. My car orignally was a 6 speed manual and has the stock ecu
Ok thank youYes. As a rule the values under the same CAN ID are the same across all the variants of the car. In general, in automatic version may be present some IDs dedicated to it's gearbox, but it would be some edge cases, as far as for other specific features depending on the car configuration...
