Many aftermarket and stock parts
8,496
8,497
I know 12coBoss very well and he is a super fast track guy and 100% reliable. He has been on BMO and TMO since 2013 and unlike me he does most of his talking on track---- he has won his Class at the Mustang Roundup numerous times. Straight shooter and you can feel confident in what he posts or tells you.
Still have the diff, it came with the boss as this was did not have the torsen option and thats what I ended up swapping in. Not sure if it is an upgrade of a 2007, may be the same thing.
Moved some parts last week so updated what I have left. Let me know if you have questions, follow the craigslist link for pics, I have links next to the part for more details.
All parts are used and came off a 2012 Mustang. I do not have pictures of everything yet and will post them up once I do, I have links beside the item to see what they are. Dsport and eneki wheels were used for track so do have scratches on them. Text if you have questions show contact info
X brace, rear seat delete-$1,200-https://www.americanmuscle.com/frpp-xbrace-seatdelete-0513coupe-gray.html
2 gauge A pillar-$50 -https://www.lethalperformance.com/autometer-2010-2014-mustang-dual-gauge-pillar-pod-hard-top.html
2 aeroforce gauges -$450 -https://www.lethalperformance.com/aeroforce-ford-cn-series-single-interceptor-scan-gauge-2011-ford-vehicles.html
LS splitter-$550-https://www.steeda.com/ford-racing-mustang-boss-302-laguna-seca-front-splitter-161-m-16601-mb.html
sve wheels 18x10, 285 MPSS-$900 -Michelen Pilot super sport tires/285s, https://lmr.com/item/WK-1007DEK/Mustang-SVE-Drift-Wheel-Kit-19-Flat-Black-05-14
dsport wheels pirelli 305 tires-$700 -vorshlag wheels not produced anymore 19#'s/piece, take off pirelli 305 slicks
eneki wheels and pirelli take off 305 tires -$700 -https://cortexracing.com/product/enkei-pf01-1-piece-high-performance-light-weight-wheel-18-x10-5-47mm/; with take off slicks
5 used slicks, 18"/305s Pirellis-$80 -take off slicks
Fire extinguisher bracket-$80 -similar to this; https://www.blowfishracing.com/safe...uick-release-fire-extinguisher-mount-kit.html
brake pads, glock R18s, XP24s, 5 used sets-$200 -http://www.g-locbrakes.com/products/brake-pads/search/
3 rear rotors, frozen rotors-$150 for all -https://frozenrotors.com/rear-left-or-right-frozen-rotor-1941-fzr.html
sparco seat-$600 -https://www.sparcousa.com/evo-ii
2 sparco slider brackets-$150/piece -https://www.sparcousa.com/product/seat-base-600-series; https://www.sparcousa.com/product/side-mount-steel; https://www.sparcousa.com/product/track-set-slider
g-force cam lock-$40- over 2 years old, needs reweb, $110 to reweb-http://www.gforce.com/product/pro-5pt-pd-lap-ind-shld-cam-black/
3.31 gears-$100 -https://performanceparts.ford.com/part/M-4209-88331
differential-$100 -https://www.tascaparts.com/oem-parts/ford-differential-ar3z4026a/?c=Zz11bml2ZXJzYWxzLWFuZC1yZWFyLWF4bGUmcz1kaWZmZXJlbnRpYWwmaT1GMjExMTA0JnI9JmE9Zm9yZCZvPW11c3RhbmcmeT0yMDEyJnQ9Ym9zcy0zMDImZT01LTBsLXY4LWdhcw%3D%3D
Stock parts from 2012 Boss 302
Drive shaft-$100
Exhaust manifolds and gaskets- $100
Boss H pipe with side pipes- $250
Mufflers-$100
front and rear springs- $50
Adjustable front struts- $100, do not have the rear shocks
Front sway bar- $50
8,496
8,497
Holy Cow you had a lot of stuff on your car -----did Grant help you spend so much money? Thanks for posting I know there are some things others are looking for right now ( rims in particular ) and pretty sure you will be moving alot more stuff in the coming weeks!!
Smart to repost as helps folks see what is left of the million and one parts you modded your car with, ha!
