Many aftermarket and stock parts
Dave_W
1,007
1,314
I see you're selling a 2012 LS splitter - do you have the M-17A626-MB bracket available? I've got a '13 Boss, so the splitter won't work, but the bracket works across years. Thanks.
Still have a few parts left. Sold quite a bit already, but let me know if you have questions. Some day I will put more details in on the items, but think most can figure out what it all is if they are interested, follow the craigslist link to the ad for some pics.
All parts are used and came off a 2012 Mustang. I have links beside the item to see what they are. Dsport and eneki wheels were used for track so do have scratches on them.
X brace and rear seat delete-$1,200-https://www.americanmuscle.com/frpp-xbrace-seatdelete-0513coupe-gray.html
2 gauge A pillar-$50 -https://www.lethalperformance.com/autometer-2010-2014-mustang-dual-gauge-pillar-pod-hard-top.html
2 aeroforce gauges -$450 -https://www.lethalperformance.com/aeroforce-ford-cn-series-single-interceptor-scan-gauge-2011-ford-vehicles.html
dsport wheels with pirelli take off slicks 305/680-18 tires-$700 -vorshlag wheels not produced anymore 19#'s/piece, 18x10
eneki wheels,18x10.5 & 18x9.5, and pirelli take off 305/680-18 tires-$700 -https://cortexracing.com/product/enkei-pf01-1-piece-high-performance-light-weight-wheel-18-x10-5-47mm/; with take off slicks
5 used slicks, Pirelli take off slicks 305/680-18-$80
Fire extinguisher bracket-$80 -similar to this; https://www.blowfishracing.com/safe...uick-release-fire-extinguisher-mount-kit.html
brake pads, glock R18s, XP24s, 5 used sets-$200 -http://www.g-locbrakes.com/products/brake-pads/search/
3 rear rotors, frozen rotors-$150 for all -https://frozenrotors.com/rear-left-or-right-frozen-rotor-1941-fzr.html
sparco seat-$600 -https://www.sparcousa.com/evo-ii
2 sparco slider brackets-$150/piece -https://www.sparcousa.com/product/seat-base-600-series; https://www.sparcousa.com/product/side-mount-steel; https://www.sparcousa.com/product/track-set-slider
g-force cam lock-$40- over 2 years old, needs reweb, $110 to reweb-http://www.gforce.com/product/pro-5pt-pd-lap-ind-shld-cam-black/
3.31 gears-$100 -https://performanceparts.ford.com/part/M-4209-88331
differential-$100 -https://www.tascaparts.com/oem-parts/ford-differential-ar3z4026a/?c=Zz11bml2ZXJzYWxzLWFuZC1yZWFyLWF4bGUmcz1kaWZmZXJlbnRpYWwmaT1GMjExMTA0JnI9JmE9Zm9yZCZvPW11c3RhbmcmeT0yMDEyJnQ9Ym9zcy0zMDImZT01LTBsLXY4LWdhcw%3D%3D
Stock parts from 2012 Boss 302
Drive shaft-$100
Exhaust manifolds and gaskets- $100
Boss H pipe with side pipes- $250
Mufflers-$100
front and rear springs- $50
Adjustable front struts- $100, do not have the rear shocks
Front sway bar- $50
8,499
8,501
Some of you new guys looking for rims , note that 12coBoss has a set of the 18x10.5 inch Enkeis many of us got years back, so we could get wider rubber on the car. 295s or even 305s were put on those rims by many. If you are just getting started and wanted a second set, these could be ones to consider if your budget does not allow new. I had a set on one of my previous Boss 302s and they are really slightweight track rims. I happened to have a set of 295/18 Hoosiers on my rims back in the day.
Updated my list again, edited a few prices, and added a few more parts. link to craigslist has all the photos and my contact info.
$900- X brace and rear seat delete-https://www.americanmuscle.com/frpp-xbrace-seatdelete-0513coupe-gray.html
$50- 2 gauge A pillar-https://www.lethalperformance.com/autometer-2010-2014-mustang-dual-gauge-pillar-pod-hard-top.html
$400- 2 aeroforce gauges-https://www.lethalperformance.com/aeroforce-ford-cn-series-single-interceptor-scan-gauge-2011-ford-vehicles.html
$700- d-force wheels with pirelli take off slicks 305/680-18 tires, plenty of tread left -vorshlag wheels not produced anymore 19#'s/piece, 18x10
$700- eneki wheels,18x10.5 & 18x9.5, and pirelli take off 305/680-18 tires- https://cortexracing.com/product/en...performance-light-weight-wheel-18-x10-5-47mm/
$80- 5 used slicks, Pirelli take off slicks 305/680-18
$75- Fire extinguisher bracket -similar to this; https://www.blowfishracing.com/safe...uick-release-fire-extinguisher-mount-kit.html
$175- brake pads, glock R18s, XP24s, 5 used sets -http://www.g-locbrakes.com/products/brake-pads/search/
$150- 3 rear rotors, frozen rotors- for all, 1 is new in box, other 2 were used for one track day- https://frozenrotors.com/rear-left-or-right-frozen-rotor-1941-fzr.html
$600- sparco seat-https://www.sparcousa.com/evo-ii
$150/piece- 2 sparco slider brackets -https://www.sparcousa.com/product/seat-base-600-series; https://www.sparcousa.com/product/side-mount-steel; https://www.sparcousa.com/product/track-set-slider
$40- g-force cam lock- over 2 years old, needs reweb, $110 to reweb-http://www.gforce.com/product/pro-5pt-pd-lap-ind-shld-cam-black/
$75- 3.31 gears -https://performanceparts.ford.com/part/M-4209-88331
$100- differential -https://www.tascaparts.com/oem-parts/ford-differential-ar3z4026a/?c=Zz11bml2ZXJzYWxzLWFuZC1yZWFyLWF4bGUmcz1kaWZmZXJlbnRpYWwmaT1GMjExMTA0JnI9JmE9Zm9yZCZvPW11c3RhbmcmeT0yMDEyJnQ9Ym9zcy0zMDImZT01LTBsLXY4LWdhcw%3D%3D
$30- BMR panhard bar relocation bracket- https://www.americanmuscle.com/bmr-...bvSbRddOwJ4HBBAg2QwaApFUEALw_wcB&gclsrc=aw.ds
$15- front no drill license plate bracket, easily install and remove front license plate
$75- Drive shaft
$75- Exhaust manifolds and gaskets
$250- Boss H pipe with side pipes
$75- Mufflers
$100- Adjustable front struts, with springs and strut tower mount
$50- Front sway bar
$75- vented differential cover- https://www.cjponyparts.com/ford-pe...4gMSUouojAkngg-HzQXiwZxqjZA7nJWUaArWOEALw_wcB
Updated pricing and list.
$800- X brace and rear seat delete-https://www.americanmuscle.com/frpp-xbrace-seatdelete-0513coupe-gray.html
$350- 2 aeroforce gauges-https://www.lethalperformance.com/aeroforce-ford-cn-series-single-interceptor-scan-gauge-2011-ford-vehicles.html
$650- d-force wheels with pirelli take off slicks 305/680-18 tires, plenty of tread left -vorshlag wheels not produced anymore 19#'s/piece, 18x10
$650- eneki wheels,18x10.5 & 18x9.5, and pirelli take off 305/680-18 tires- https://cortexracing.com/product/en...performance-light-weight-wheel-18-x10-5-47mm/
$125- brake pads, glock R18s, XP24s, 5 used sets -http://www.g-locbrakes.com/products/brake-pads/search/
$25- BMR panhard bar relocation bracket- https://www.cjponyparts.com/bmr-pan...-f6Rxuz7vkbXBoCVQgQAvD_BwE#221=2007&year=2013
