Setrab 948 install ?
1,060
1,109
Monaca Pa
Replacing Mishimoto oil cooler and can’t use their sandwich plate with temp sender . The Setrab plate I have has no provision for oil temp sensor but I need an adapter. I need the 90 deg fitting . I’m using -12 lines and was thinking the straight adapter should work. Any thoughts about what I should use??IMG_6897.pngIMG_6898.pngIMG_6895.png
